I'm curious what kind of results you've had if you've put insulation around your insert. I would think the back and top would make the most difference but has anyone noticed significant heat output or burn time changes from insulating the sides?
I've got an exterior masonry fireplace and am trying to figure out if I'd be better off going with an insert with a bit smaller dimensions which would allow me to insulate around the sides (will have room to insulate the back/top no matter which choice), or just going with the biggest insert I can fit into the space.
So, where did you insulate (and how much) your insert, and what kind of changes have you noticed?
Thanks guys! I'm trying to decide before the end of the month and your input really helps!
