Insert not heating room or house
All I really have is oak I believe
Where have you been looking? There is a place in Douglas on the Mass/RI border that sells kiln dried, not sure of the price but I can check for you, you can also pick up the uglies for cheaper but you need a truck, they don't deliver that stuff, just the good stuff.
I'm skeptical to buy from a tree company bc whenever they say their wood is seasoned it never is
Kiln dried is guaranteed to be burnable. The oak you have now won't even be close to ready to burn until the winter of 15/16. Enviro bricks, kiln dried wood and scrounging pallets are your best option.
Yeah we'll I bought some kiln dried in the bag and it did nothing but hiss so in skeptical about it
That is strange, I practically lived off kiln dried bags last year when I didnt have any dry wood. Try a different store.
You can also use lumber scraps. I am still burning 2x4 scraps from finishing the basement last year. 2x4, 4x4, 2x6, 2x10 anything not treated or glued work.
I bought some 'kiln' dried last year from the grocery store and it hissed like crazy when burnt. Split a piece and it was 33% on the MM. I don't think there is much regulation in this area...
Oak is going to take the longest time to season. It's great firewood but it need 2-3 years to completely dry out.
If your kiln dried bag of wood was wet, let the store know. Get your money back and help other customers avoid getting ripped off.
Weight is usually a dead give away with kiln dried it should be SUPER lite in weight.
Do you have an Ace Hardware store near you?
Just FYI, out here, Ace Hardware does not carry anything even remotely related to wood burning. I was told at multiple stores that they can no longer sell stove pipe or high temp sealant for "liability reasons." Which seems strange in a state where you can basically do whatever you please and then tell the government to get bent if they don't like it.
If you have the tools to work with that steel gauge that should be fine. Tapcons work well for anchoring to brick. You can use regular silicone for sealing to the brick. The milpac would just be for around the liner.
No, not for the sides of the damper seal. Regular silicone is rated at 4-500F. But there's no harm using the milpac if you want to.
WOW mine has EVERYTHING and if you look through the stuff you can find the mismarked ones from stock that was never rotated :)
Lucky! It seems like this area is not do-it-yourself friendly for some reason, especially when it comes to heating with wood. It took me 3 weeks and 4 stove shops to find 2 45 degree elbows and a slip connector.
I think it may have something to do with the often very bad inversions the valleys around here experience. They definitely discourage heating with wood here, but if people put the time and effort into burning dry wood and burning it well, it can be done with minimal impact, at least compared to the refineries, gas wells and open pit mines around here.
But I digress. Best of luck with your block off plate BDM. You definitely need to experiment with burning some truly dry wood as well.
I just wish I had some truly dry wood to burn and have some fun with it
Try to find some pallets or untreated lumber scraps. Also look for loads of pine that you can cut, split and stack this winter. Soft woods like that only take 6-12 months to season once split, so you will have dry wood for sure next winter. Pine should be cheap/free around you too, given it's (unfounded) bad reputation, particularly in the northeast.
If you can get some Hearthwise logs give them a try. You will only need 3-4 at a time.
Address: 44 Mead St. Leominster MA 01453
Telephone: 978.479.0925
Website: (broken link removed)
also sold in CT at:
Retailer: My Pellet Store, LLC
Address: 1654 King Street Enfield, CT 060682
Telephone: 860.265.7944
Website: (broken link removed to http://www.homefirelogs.com/www.mypelletstore.com)
[email protected]
Maybe check these guy's out, I'd get a moisture meter before I bought any
(broken link removed to http://providence.craigslist.org/grd/4208157836.html)
(broken link removed to http://providence.craigslist.org/grd/4200501272.html)
Couple more
(broken link removed to http://providence.craigslist.org/hsh/4207498840.html)
(broken link removed to http://providence.craigslist.org/for/4197977383.html)
