Install B vent insert in masonry fireplace with throat damper
PLohr
7
Knoxville, TN
Hello - surprised I haven't been able to find an answer to this question.
We have a masonry fireplace with a throat damper. Is there an adapter to pass the B vent style tubing through a 5" throat damper?
Thanks for any help.
Do those things come apart so they can come out?
The damper is removable.
I guess there would not be enough room for your vent pipe to pass through?
I had a gas fireplace installed once into a masonry chimney, and I they just used a SS liner.
How big is your bvent liner? Virtually every one I've seen are 4"
Why do you need b-vent in a masonry fireplace?
Reactions: Whitenuckler
Better draft, better for the masonry flu gases can damage it, required by manufacturer
Bvent liners are single wall flexible for masonry applications
No b-vent is double wall rigid gas pipe. Flexible liners are not b vent they are simply liners
Call it what you like. They are vent liners for bvent appliances. The box says bvent liner lol. I know what "bvent" is to. It's possible they have an old unlined brick chimney with poor mortar.
I have been in the industry about 20 years now and have never heard a liner called b vent. And yes of course they need a liner even if its got a good clay liner
Yeh neither have I. I think we both know what bvent is. But the kits we use to vent a bvent appliance through a chimney are usually specifically for bvent appliances due to their diameter and lack of a direct vent liner. I'm pretty sure they are labeled as such. I'm not calling a bvent liner bvent. I'm calling it a bvent liner. That's why I mentioned this because he shouldn't have trouble fitting a 4" bvent liner through a 5" throat. Every bvent stove and insert I work on is vented via a 4" liner. Maybe he is trying to install actual bvent through his chimney. If that is the case I'm puzzled as well
On page 31 I found oval kits. Maybe that is what the OP was looking for?
Who knows. Without knowing the appliance and required venting we are just guessing. I think bholler and myself were trying to say the same thing but using slightly different terminology for flexible liners that are used for bvent appliances in masonry chimneys. If it's a bvent insert I would use a flexible liner connector to the insert. If it was a free standing stove I would use flexible liner to the stove but also use a section of smoke pipe to cover it if visible.
Reactions: bholler
