I need to install a thimble that will go into a block type clay lined chimney. (broken link removed)
How exactly do you make the connection at the masonry? Do you push the stove pipe into the block flush with the inside clay liner and use regular morter around it?
Should I jam some rope in where the stove pipe meets the masonry and then mortar around that?
Have you a cheaper solution?
