Installing Electric Patio Heaters
Whitenuckler
1,662
PEI Canada
Just finally got my thermostats installed yesterday. I keep leaving the heaters on as I didn't get a timer going although
I'd still like to have one as well as the thermostats.
The heaters were on sale and cheap $24CAD each. 1500W 120V (regular price $49CAD Princess Auto)
Installed 2 new 15A breakers in my 200A panel, ran 14/3 to a 4 Way 240V Switch (two circuits) which is on the porch wall.
From there I run to a split plug (split like a kitchen plug). I leave the switches on the heaters on all the time.
I just installed 2 electric heater thermostats. Used 1/2 conduit. If you are think about adding some heat this is good. They are
radiant quartz heaters so you can use them in the winter. They were so cheap I bought them for the garage too.
  • [Hearth.com] Installing Electric Patio Heaters
One thing to watch on these is the cords are underrated and get hot after long term use. Also why did you mount the thermostats on the ceiling heat rises so the heat will be shutting off before the lower area gets to temp?
I do know that they say not to use extension cords with them, but I am plugged in. Should be 12.5A. I will see how hot they get. Well to be honest I wanted to mount them on the house wall at about mid height but I only had a little bit of wire left and a little piece of conduit. I am playing with the settings right now to see what would work best. I really wanted a timer, but I would have needed a special timer as it's two high power 15A circuits I need to switch. I have a 600V contactor I could use, but need to get a metal box and install it next to my panel. Then I'd use one of my smart wifi plugs to drive the coil.
Also, I should have mentioned that the porch is uninsulated. I only turn the heaters on before I go out, then I try to shut them off when I come back in. I don't like to discover that I left them on $$$$. The thermostats I will only have at maybe 10C.
Just finished up installing my new 2000W 240V heater in the basement next to the pellet stove. Ouellet ONC.
I'd like to say it only took a couple of hours, however it was fairly difficult to route the #10/2 cable. I opted to use
#10 as I have it tied into an existing 30A CCT. Really kicks out the heat. With the warmer days coming I will be using
the stove less. I had a heat pump head in the basement before, but moved it upstairs for cooling duty. This is the replacement
heating source. I don't seem to need cooling down there, and just got a de-humidifier for this summer which I needed anyway.
Hello
I built a 240 VAC 900 Watt Electric heater with convection fan right into the bottom of the raised hearth for the pellet stove to save room and added little rope light for a nice warm glow around the tiled hearth with a mantel and a couple candles in it.
How does it look?
See pics here
Hello
How does it look?
See pics here
Great job. I like it. I'm not sure what my plan is for the pellet stove. The installer included just a 20 guage or very thin black corner pad to meet code as I have laminate flooring. I may look at the Harman cast iron corner pad to see if it would fit. I have a door right next to the stove so I had the get them to trim an edge off to be flush. Thanks for sharing !
Hello
How does it look?
See pics here
Found some pics of similar work I did for a gas fireplace. The mantle and other shelves were done by a company but I installed it all.
