Is a wood burning fireplace insert right for me?
BlueridgeDsve
2
North Carolina
I have a vacation home in the southern Blue Ridge Mountains of Western North Carolina. We have a Masonary stone fireplace that we use very often, 9 months of the year. We are at high elevation (around 4,000 ft) so even summer nights can be cool (but not cold). Winters are cold but rarely frigid, with daytime highs in the 40’s and nighttime lows in the 20’s. We have occasional cold snaps into the low teens. The house is heated with an electric heat pump which heats it just fine. The home was built in 2002 and the insulation is good.
We enjoy the fireplace mostly as ambiance but we use a lot of wood due to inefficiency. My question is: would a high efficiency insert be too hot for us even with the central heating off? Also are there any inserts that allow you to burn with the door open so that you can hear the fireplace crackle (with fireplace screen)? This would be nice because sometimes we would not want it to warm up the house too much.
I guess what I want is the best of both worlds, ambiance for cool nights, and efficiency for really cold ones.
Any advice would be appreciated.
  • [Hearth.com] Is a wood burning fireplace insert right for me?
I’ll post on your question if nothing more than to bump your post to the top. I can’t answer your questions other than your comment wanting an insert for efficiency yet you want to run it with the doors open, kind of defeats the purpose of gaining efficiency with an insert. The other consideration would be over firing the insert with the doors open causing damage?
With a high efficiency insert you could still achieve your ambiance without overheating by lighting smaller fires. But generally most inserts are designed to run door closed.
The likelihood is that there is a good compromise. One does not have to have a full-load fire buring in mild weather. Some inserts even permit open door burning with a screen accessory.
It would help to have more information for specific advice. Tell us more about the area size being heated. Are there high ceilings? Is the fireplace room wide open to other places in the house or closed off by a doorway?
I think it would be hard to beat that look you have now. Martha Steward would be impressed. Maybe keep that the way it is and get lots of wood. If you were to get a pellet stove that could supply heat.
Edit - Also if you lose power up there you could use another heat source. A pellet stove can run on batteries/inverter/generator.
Do you get much smoke smell when burning??
Do you want to heat with wood?
Are you ready to keep wood stacked and dry for at least two years?
