SolarAndWood said:iceman said:the 30 to the t6?
or did he get rid of the 6??
I think he stuck with the T6 in the end.
Yeah, it took him a month, but he finally broke down and tried the blower.
BeGreen said:And insulated plus started sealing up leaks.
PS: Note the goal was to be able to go butt naked (80+ inside) when it was minus 10 and blowing at 50mph outside.
SolarAndWood said:Hogwildz said:In the time I have belonged to this forum since 2006, I remember seeing many posts from folks that bought a smaller stove and regretted it. I don't remember one post of someone complaining their stove was too big.
+1. Moosetrek's was probably the closest to a complaint and he resolved it by buying an equally big replacement. As far as the never ending cat/non cat debate, there is a place for both and both perform far better at low burn with dry wood. My current stove is much bigger than the old one with the ability to burn both higher and a lot lower. This is great because it sits in a room with 300 sq ft of south facing glass on a windy ridge that has huge swings in heat demand. The bigger stove has also completely eliminated even thinking about getting up before I am good and ready.
BeGreen said:And they insulated plus started sealing up leaks.
Hogwildz said:Now that I live alone, I can run around buck naked any time I damn well please
Its not as fun alone though. hahaha
LOL, thats cats took off with the OL. Only one seeing my sorry arse naked is the walls.tiber said:Hogwildz said:Now that I live alone, I can run around buck naked any time I damn well please
This is why your cats hide under the stove. I too would hope my fur went alight than suffer such horrible sights.
WHAT HAS BEEN SEEN CANNOT BE UNSEEN.![]()
Hogwildz said:Then I might be complaining that the 2 large stoves are too much. But I doubt you will ever hear me complain it is too warm. Rather too warm and run the stove lower, then full tilt and still cold.
SolarAndWood said:Hogwildz said:Then I might be complaining that the 2 large stoves are too much. But I doubt you will ever hear me complain it is too warm. Rather too warm and run the stove lower, then full tilt and still cold.
I think that is my next step. I run mine wide open whenever the wind is blowing which is most of the time here. The lower level is unheated right now but should be built out this summer and will likely have a matching King. I think between Tyvek, foam board, siding and a second stove, they should be able to cruise along at a fairly low burn and get the job done. Maybe even get away without running the blowers.
boiler or wood furnace... wish i wood ahve gotten one instead of a stove... ... yeah my electric would go up but not as much as running ac... then my WHOLE house could be one even temp! as it is now i run 3 fans to move the air in the house due to layout and size... and those are 20"ersSolarAndWood said:That's funny. I'm torn between the boiler and the second stove. While the boiler gets me to a single fire, it is a lot more money, requires electricity and means starting a fire every day which I have never done and really have no interest in. Still have some thinking to do on that one.
iceman said:boiler or wood furnace... wish i wood ahve gotten one instead of a stove... ... yeah my electric would go up but not as much as running ac... then my WHOLE house could be one even temp!
Except for Wood stock Fireview, add 30%Todd said:Good rule of thumb for northern climates is to knock off about 30% off most of the manufactures sq ft heating specs.
