You could try Woodmans. It looks like you could get all 4 for around $250.
(broken link removed)
That looks a lot better then all most $400. Thanks NaterNater said:You could try Woodmans. It looks like you could get all 4 for around $250.
AppalachianStan said:Is it ok to use liquid ranch on the bolts inside the wood stove?
leeave96 said:I probably missed it, but does your stove have the old catalyist combustors in it? If so, do you know if they are bad? If they are there, I'd burn the stove with them as some catalyist burn is better than none.
Good luck,
Bill
AppalachianStan said:BeGreen said:Anyhow, to answer your original question, I would think it probably safe. The stove is just burning like most old smoke dragons when run without the cat.
I just not know about that. The old smoke dragons got a lot more air then this stove does and i geuss that is way I have all ways thought the stove was not getting enough air IMO.
mellow said:You could also try kroil oil, that stuff works wonders but its hard to find.
central_scrutinizer said:Of course you CAN burn the stove without the cats, but you will be lessening it's efficiency, it's ability to heat, and possibly damaging the stove or creating a lot of creosote build-up in your chimney. You will burn twice as much wood without the cats as you would with the cats being properly used. For this reason alone, it would be well worth replacing the cats.
