I have dis-coloration at the very top of my metal chimney. And the cap is looking black. Only been using the stove a few weeks. Any clue?
Timebandit said:I have never had the stove up ovr 425 dgrees.
Timebandit said:No dont think its wet wood. Less than 20% moisture content. I have never had the stove up ovr 425 dgrees. I dont think my burning technique is wrong either. Start with lots of newspaper and nice dry kindling(i think thats how you spell it). Fire burns nice. Any advice?
Timebandit said:I took the reading from an old split. The splits are thin, not to thick. If this is my problem , will i have a chimney fire?
Jags said:Timebandit said:I took the reading from an old split. The splits are thin, not to thick. If this is my problem , will i have a chimney fire?
I think Mike is trying to figure out your "method" of testing the split. The split needs to be RE-split at the time of testing. The newly exposed area is where you need to test at.
This doesn't mean that you WILL have a chimney fire, but abnormal creosote production will increase the dangers. Proper stack maintenance will mitigate this as well as the easy thing - and that is to burn cleanly with properly seasoned fuel.
Pagey said:I think it would be wise to check your chimney for buildup. I have a discolored spot on about the last 1/3 of the final 3' run of my exposed Class A on the north facing side. This discoloration, I assume, has to do with heat and prevailing wind direction. I check for creosote buildup routinely, and I sweep routinely (pretty much monthly during burning season), and I've never had any excessive creosote problems.
So your discoloration COULD be unrelated to actual creosote buildup, but to be safe and to gain knowledge, you definitely need to check it.
mikepinto65 said:Pagey said:I think it would be wise to check your chimney for buildup. I have a discolored spot on about the last 1/3 of the final 3' run of my exposed Class A on the north facing side. This discoloration, I assume, has to do with heat and prevailing wind direction. I check for creosote buildup routinely, and I sweep routinely (pretty much monthly during burning season), and I've never had any excessive creosote problems.
Discoloration is one thing and I agree with you, black is another and so I sort of disagree with you too![]()
brokeburner said:discoloration means that it has been hot enough to heat the metal to red or dull red. When it cools down you get discoloration. What color is it? Does it have a blue tint to it.
Jags said:Timebandit said:I have never had the stove up ovr 425 dgrees.
I think I see your problem.
Your oak is not ready. Small splits will help, check your chimney at least once a month and clean as needed.mikepinto65 said:Timebandit said:No dont think its wet wood. Less than 20% moisture content. I have never had the stove up ovr 425 dgrees. I dont think my burning technique is wrong either. Start with lots of newspaper and nice dry kindling(i think thats how you spell it). Fire burns nice. Any advice?
Right youve said that in your other post but you never answered a previous question....did you take the mc from the end of piece of wood that was split in February or did you re-split a piece and take the reading from the core? Also fwiw, not that this'll help you, oak split in Feb is not seasoned and ready for burning.
