My first post, just say so if I’m doin it wrong.
I have installed the insert in the firebox and the chimney is lined with tile that looks to be in good shape.
I pushed 8’ of 6” galvanized 30 gauge pipe up the chimney in hopes of improving draft.
I plan on taking it all apart and doing it right come spring but I’m renovating an old house and needed to get the old Vermont castings off the floor.
All seems well right now but I know the “pipe” is more like duct and it isn’t to code.
Since the chimney has a tile liner, which appears to be in good shape, isn’t the pipe kind of redundant? Other than improving draft?
The previous owners had 36” of 8” horizontal pipe from a Vigilant dead ending at the chimney flue and I cleaned out a solid 2’ of fluffy creosote. Scary stuff.
The answer to “why not just do it right” is, of course, money.
Your thoughts are appreciated.
Galvanized pipe can not be used in a chimney, it must be stainless steel. The liner may stop when it it is in the tile liner, but then it requires a damper area sealing block-off plate. This is to create a seal to the chimney and prevent the reverse drafting of flue gases. As you have discovered, it is a poor way to connect a stove for a number of reasons. The flue size changes allowing flue gases to slow down and cool off. This causes creosote to build up as it condenses on the cool chimney tile walls. It can also lead to poor stove performance leading to dirty burns and more creosote accumulation. The stove should have a full stainless steel liner from insert to the top.
