hey guys, I have a jotul 118B mfg Feb 1980. Believe it or not it’s essentially brand new. Was used the winter of 1980 and never again. I want to put this stove in my living room which has no hearth. I will have to run the chimney through the ceiling up through the attic and out the roof next to another chimney for the oil burner. I am going to get an insulated steel chimney and chimney support box for that part. Was thinking Metal Fab? What I am trying to figure out is what I need to do inside so I don’t burn my house down. I am thinking of cutting the drywall away packing the wall with Roxul. Then putting two layers of cement board on that, and then a stone or imitation stone on that. For the floor, I am going to get a pre manufactured piece to set on top of the hard wood. As far as I am aware there are no heat shields for the OLD 118B. Is that correct? I am going to try for a corner install so I will have to do two walls. I was thinking going 3 feet up. Does this sound adequate or am I missing something?
![[Hearth.com] Jotul 118B install advice [Hearth.com] Jotul 118B install advice](https://www.hearth.com/talk/data/attachments/224/224192-b671974a268af7cbfff14b7a43108095.jpg?hash=PyFvlFHCJq)
