Hi All,
I ended up purchasing the Jotul C350 for my 1850 sq ft colonial in NE MA. I realize that the C350 is a bit undersized for my house but made the decision to go this route because of modest heat expectations and was one of two inserts that my wife was agreeable to, the other being the 550 but that would have required substantial modification to mantel and as a result was ruled out.
Anyway, temps have gotten down to 30's the last couple of nights so we've been burning the stove and it really isn't generating much in the way of heat output e.g. when I walk into the living room (22 x 14) where insert is located there is hardly a noticeable difference between temps there and rest of house. Frankly doesn't seem to kick off any more heat than the fireplace did - maybe less.
The C350 was installed with full SS liner (not insulated) and block off plate. Stove temps have been steady around 400 degrees, getting as high as 500 or a little over at times. I can feel decent heat coming out from immediate blower area but was really hoping that at least the living room area would get warmish.
Am I doing something wrong? Are my expectations off? Also, not clear from Jotul manual what the optimal burn temp is for c350 if anyone can shed light.
Thanks,
Oliver
Thanks,
Oliver
