Jotul Castine - my solution to a hot ashpan
ailanthus
390
Shen Valley, VA
No welding gloves & I was having a hard time taking the hot ashpan out in the morning: Here's my low tech hack solution. It's very stable. The vertical screws are to reinforce the weakness of the grain and the horizontal screws are to keep the pan from resting directly on the wood. It cracked a little where the two screws came together, but I didn't feel like remaking it. Same design should work for the oslo as well & maybe some others.
  • [Hearth.com] Jotul Castine - my solution to a hot ashpan
Nice! How often do you empty your pan? I've been running all season and haven't dumped my pan yet - I scoop the ash directly from the firebox every 6-8 loads.
Having the ash pan makes life easy. Only the most fine ash will enter. I will run my rake back and forth so the ashes go down it, and empty it every few days, when burning 24/7. Welding gloves work good, when you get a pair of them.
I think it would just be easier to purchase a pair of welding gloves that you could also use while loading the stove . . . plus it seems to me grasping the pan with two hands wearing welding gloves would be more stable.
I empty the pan about twice a week this mild winter, usually well before it needs to be. I really don't understand how people scoop ashes into a bucket inside the house - does this not make a tremendous amount of dust? For me, the castine has been making ash about as fine as flour & the stove's in my living room.
Stability isn't a problem - I can essentially turn the pan upside down to empty it before it comes loose. I do wear a heavy leather glove on the off hand in case something were to get tipsy, but never had to use it. I'm sure welding gloves would be easier in some ways, but I hate buying a solution to every little problem if I can avoid it. Haven't ever felt that welding gloves would be at all necessary for loading the stove & I didn't want to get them just for dealing with ashes.
Check the 'Burned' threads for more information about loading the stove. Good luck.
Wow, Just read the "burned threads" I never knew there were so many ways to burn yourself on a woodstove. Sounds like I would need welders gloves AND a welders helmet. Prob'ly just take my chances, though :)
Have you ever tried not dumping the ashpan? I dump my Oslo once a year at the end of the season and my bro does the same w his Castine. I only shovel out the box once every two weeks or so. I tried your way for two years before using the new method and find burning much better and easier the latter way.
