First, let me just say thanks in advance to the moderators and all the contributors to this forum. This site and forum is probably the best resource.
So I have, the same basic question: Advice on a New Stove. With a couple of additional questions.
I started my research alittle over two years ago when I was designing my house. After living in it for 11 months I am just getting around to actually purchasing a stove and my research has been more intense and like every newbie my head is hurting with information overload. So in the last couple weeks I have visited several dealers. The brands of stoves that are in the running are the Jotul F 500, Lopi Liberty (or perhaps smaller) and from this forum the Pacific Summit. I have settled on the Jotul F 500 primarily from an aesthetic perspective. It is going to be the focul point when you first walk downstairs and overall So basically, is this a good choice from an operational stove for my basement? With these considerations:
I live in the Midwest
Average Temps (High) in cold months is 28-58 degrees F.
Average Temps (Low) in cold months is 14-40 degree F.
My house is new and very tight and well insulated (6 inch insulated walls, 12 inch batt, 38 inch blown in attic), Mostly Brick
Temp in basement is typically 64 degree and furnace never even turns on
Basement is unfinished at ~2100 Sq Feet. The picture has a "design" but it is not finished right now. I expect it to be 1200-1600 sq ft of finished living space.
The chimney (brick) is a metal (6 inch) and is about 38 feet long up the back of the house
It (the chimney) has two 90 degree turns and a couple of 30 degrees been
This wood stove would not be a 24/7 stove (although from reading this forum it sounds like you get hooked and use it more than you think). Supplemental heat for the basement and I viewing of the fire is what we want.
The advice I got from a dealer is that the Lopi Liberty is easier to operate (gets hot quick and easy damper control) and will prime the heat the flue better. That got me questioning my Jotul decision. Is the Jotul 500 that much harder to tame? For a newbie? Even if it is just going to be used when we are downstairs or at night? The price I got for the Jotul and Lopi Liberty is the same. The dealer indicated that the Jotul requires more maintenance but I cannot validate claim either.
Here are my other questions:
I have had my wood seasoning since last April (Mostly Cherry) is that long enough? Not sure if I should buy wood for this season.
I have a negative air flow mechanism on my furnace. I have read about outside air kits here. Would I need it?
Can I install the stove myself? Besides the weight of the darn thing the the installation looks pretty straight forward.
Aside: I really like the side loading feature of the Jotul. Is that as important as I am perceiving it?
Any other newbie advice would be appreciated.
