I'm uploading pix/house layout below for best advice between F3CB vs Castine F400 (hopefully they uploaded correctly)
House: its called a "carriage" house or duplex (two houses squished together). ~2465 sq ft, 2 story, 1989 construction, good-fair insulation. We do not have a open floor plan, and can only place stove in Fam Rm against wall. Good thing is Fam rm faces north (no sun from Oct-Mar), cold side of house, alongside of garage, one sliding glass door recently installed Anderson well insulated, normal 8' ceiling. Two registers and two return registers are opposite side of room to help circulate, and will be installing ceiling fan. Existing system is HP (forced air). The wall running from fam rm to living rm is an insulated wall adjoining our neighbor, so opposing rms are the the exposed areas.
Live in Chester Cty/ SE PA,. When temps go below 15 degrees our 2 yr old Trane HP struggles (this has been the first winter in seeing this) and single digits, well I run a Delonghi radiator over the registers in my daughters room to keep those at 65.
Existing in Fam rm is a '89 prefab Martin Industries FP, which hubby will pull out, demolish drywall bumpout and build up hearth (still processing on this) and drywall (or Durock) the back wall. Chimney stove pipe/liner will be purchased for 35' of existing chimney which has a good height to our roof line. We use a Kerosene heater that cranks out 9300 btu for times when we want heat in that room, but after 4-5 hrs is so hot in there we need to turn off. Hubby wants heat for fam rm - kitchen area, I would like heat more of the 1st level.
1st stove shop near to us, rec. F3 CB, only thing I had alarm bells go off, is when he was showing how it starts, he mentions "in some cases" we might have to leave the ash pan open "to get air in there for a real hot burn for a start up", which I read all over this forum is a big "no-no". He was mentioning we probably would not get the Castine up to temps that would burn off creosote, since we'd probably keep it on low burns or make smaller fires since it would crank out so much heat.
This is starting out as a "weekday eve/ weekend burns" heating system (mainly when temps go below 30). Though some of those bitter cold temps we got this past month I wonder if we would be evolving to longer burns.
Sorry for typing a book load of info, I keep reading "discussions" between F3/F400 models and hope if I post a house layout someone will feedback a good explanation over one/other model. Thanks!
the ZC FP already has issues in that the back wall is cracked, rec'd quote of $325 to replace.
