Jotul F500 V3 Oslo, I pulled the trigger.
Good sleuthing. The devil is in the details.
The fact that it still read 1100 when it was out of the stove points to something else going on besides a magnet not holding it in position on the stove..unless this isn't the bi-metallic strip type of meter that I'm familiar with. Maybe that's why they're sending a new one?
Once I removed the magnet the temp went down. Also when I put the magnet on correctly the temp continued to go down and is now working correctly.
Glad you knocked down the old masonry chimney. It’s really easy and people suffer with them even though the pipes work better because they think demo is hard.
I replaced a cracked masonry fireplace with a pipe and don’t regret it.
I have taken down enough masonry to know many times it is not easy. Yes if it is in need of extensive repair or you are in an area with lots of seismic activity it probably makes sense. But for most people with a decent masonry structure it is cheaper and easier to simply install an insulated liner. And they work just as well.
The chimney was too far gone for a liner.
OK, I hadn't thought it through..the magnet facing the spring was exerting pull on the spring. Duh... ;lol
And why trade the aesthetics of a masonry fireplace for a black pipe, if you don't have to?
That said, I'm in a 'quake zone so I should probably think about what precautions I could take..
Reactions: Amigo Azul
The chimney was to far gone for a liner.
Yes that absolutely happens I wasn't referring to your chimney really. Just addressing the statement about taking down a masonry chimney being easy and that prefab pipe is much better. Sorry for the thread wander.
Yes that absolutely happens I wasn't referring to your chimney really. Just addressing the statement about testing down a masonry chimney being easy and that prefab pipe is much better. Sorry for the thread wander.
No worries.
Many of the chimneys in question aren't fireplaces either. But I agree I prefer the aesthetics of a nice masonry chimney.
Yeah, I guess the smaller they are, the more easily they can become unstable, and then would need to be addressed.
Hi Amigo, that is a good burn time. I just purchased the F500 V3 about 5 days ago and can't get over a 6 hr burn time on lowest setting. If I pack the box full of 20 inch maple at night 8 hours later there is not enough coals to start a fire, which is a PITA having to start a fire 1 to 2 times a day. I have the 6 inch pipe going into an 8 inch insulated with a total of about 18 feet, I"m thinking I might have too much draft.
We are experiencing the same thing. With the primary air on low 5-6 hours is all it’ll do. 500 is about as low as the stovetop will get. I think something is possibly wrong with it? I have got a chance to tear into it.
Amigo, does your air control lever move equally as far to the left as it does to the right from center?
Yes, It is equal in both directions it goes all the way to the + and back to the - on mine. My stove top on low will be 400ish according to the Rutland. This is with a nice slow bluish flame from the secondary’s and a light red glow from the cat.
Ours never has lazy flames. The air control lever doesn’t go as far to the left as it does to the right. I think I know what the problem is... I’ll take it apart tomorrow and see what’s up with it.
Wow, that looks great. Where is the cat located in your stove?
Right above the door.
Wow, it must contribute quite a bit of heat and can probably allow the stove to be run lower if anything. The cat itself must act like a baffle which would add more turbulence and allow a greater chance of gasification Ignition as well. Seems like a home run for Jotul.
Wellll maybe. The stove has no bypass so everything goes through the cat all the time. No one has been successful in the past without a bypass. Only time will tell.
Reactions: webby3650
I’m all for the addition of the catalyst, and am hopeful it holds up. It’s huge, nearly the entire width of the stove. If it fails, it will be very costly.
My Oslo would run really low, but after a little bit it would lose secondary combustion and start smoking, unless the air was increased. Since the cat has thermostat controlled secondary air, hopefully it can run on low without smoking. If our V3 had low...
What is the warranty on the cat? What is the cost of replacement?
the warranty states 20 years for the cat. I'm not sure about cost replacement as I haven't asked my dealer.
the warranty states 20 years for the cat. i'm not sure about cost replacement as I haven't asked my dealer.
Excellent. According to the EPA testing, they were able to run the stove as low as 14,001 BTUs and Max at 38,804 BTUs. Longest burn time was 410 minutes on ~19# of fuel (doug fir).
Interesting to note that some of the test fuel (dimensional lumber) had a moisture content as high as 25%.
Wow, that's a great burn from doug fir crib wood. 19 lbs even seems like a small load for a larger stove like this one. Perhaps Jotul has finally gotten their cat stoves to work well!
I can say after 2 weeks I love mine. It has burned everything I have thrown at it. I'm at the part of my wood shed with the stuff that was on the bottom of the pile for a couple of months. I mix it with the other wood and it goes up just fine.
