I just discovered an unfortunate problem with my 2008 Jotul F600. Apparently water has been coming down my chimney in the non-burning months and reached a point where I found serious corrosion.  I always pull the interior chimney off each fall for cleaning and inspection, and the issue was not evident a year ago, but today it was depressing.  Here is what I found:
The collar that attaches the stove to the chimney is done. Heavy corrosion on the inside that the bolt holes had cracked. Significant rust and corrosion on the back inside of the stove, to the point that I can readily scrape up layers of mushy metal. The wool insulation over the interior top plate was soaked with ash and moisture, and the plate below was cracked in several places. There is also evidence of rust in other places along the back (had been concealed by heat shield) and on the rear bottom of the stove. Basically, I am guessing that the stove is going to need a partial rebuild with some substantial parts required.
My chimney is all vertical with no bends; 8' of interior double wall and then almost 20 feet of excel exterior pipe and an excel cap. The chimney and cap all look to be in excellent condition and there is no other source for the water but down the pipe from the top. What is vexing is that I had a Lopi stove in the same spot and configuration for 8 seasons without issue, and that stove now has 5 more seasons in my shop with the same kind of chimney setup and there is no evidence of water issues in it (it also hardly ever gets used).
Is this just a reality of cast iron versus steel? I assume that if I rebuild the Jotul I will be in the same boat in another 5 years unless I prevent water from getting in there in the off season. Any thoughts on a fix? Cap the chimney when burning season is over? Does anyone have any experience with doing a Jotul rebuild? Seems like a royal pain given that all of the fasteners look to be badly corroded, so I am assuming that everyone bolt is going to be a project.
	![[Hearth.com] Jotul F600 and water coming down my chimney [Hearth.com] Jotul F600 and water coming down my chimney](https://www.hearth.com/talk/data/attachments/118/118084-0b0de1b31a0929a518da59853081ab5a.jpg?hash=CFmhLCS7GA)
