Hey Everyone
First off, thoughts, I just want to say thanks so much to all for being active members of this community! I'm excited to join. I've been reading the forums seemingly non stop for the past month or so trying to sort out what to buy and educate myself on topics ranging from wood seasoning, proper burning techniques, insert and manufacturer reviews, catalytic vs non etc.
I finally settled on a Lopi Freedom (wanted the Freedom Bay but was shy on clearance by about 4 inches), it was between that and the PE Summit, also briefly considered the Buck 91 before I ruled out catalytic. I ended up going with the Freedom as I really liked the dealer and installer they work with. Equipment should be here and installed in the next 3 weeks! Just in time for XMas, my wife told me this is my gift, the gift of a budding wood burning addiction, little does she know!!
So now that the ball is rolling, I'm trying to figure out some things.
First question for you, does anyone have a preferred accessory set? Specific items that are going to make regular wood, insert, and ash maintenance easier? I have an old fireplace set I was using for the open hearth but I'm not clear that I even need a poker and log lifter with an insert. So I'm considering at least the following accessories as must haves: Wood moisture meter, Ash bucket + Shovel, indoor log rack for the kindling and logs to be used that day (must be functional and ascetically pleasing, aka wife approved). And that's about it, am I missing anything? Ash vac? Already have most of the things I need for wood, chainsaw, maul, axe, hatchet, grenade, etc. (come to think of it, all handy for a zombie invasion too)
Second item is about air distribution and whole house heating. My house is about 2600 sq ft, mostly open floor plan but a few of the bedrooms are tucked around "L" shaped hallways. I've read extensively in the forums on the ideas of floor fans, people's general experience using HVAC ducts and furnace fans (mostly fail though some with luck here) and I'm thinking about trying my luck with using my HVAC ducts and my furnace fan to help move the air around the house.
Background: We live in a pretty mild climate, coldest nights are in the upper teens and more regularly in the 30's (downright balmy for most of you!). I just did a non scientific mid-day test of my heat loss via my furnace fan and only measured a loss of about 3
, The air has to go into the (single) cold return that's in the same room as the furnace about 30 ft away, near the ceiling, through the attic, to the furnace and then down through the crawlspace to get to the far bedrooms but even at the farthest point the drop in temp was only about 5
. Either it's almost room temperature in the attic and crawlspace or the original HVAC installers did a really good job... I'm also planning on adding an additional return in the same room as the insert at the very top of the cathedral ceilings where the skylight "pools" are. This is surely where all the heat will build up so in theory should help with heat distribution. Additionally, I have ceiling fans in every room, plan is to have them on in the open common areas (and the bedrooms??) pushing air down to also help with circulation.
So I guess my question on the above is, do you all think I'm crazy?
