Keeping warm air downstairs
StairFanMan
3
UK
Okay look, I am going to risk it and admit this isn't technically a question involving a wood stove - please forgive me!!
The reason I want to ask a question is because of the nature and dynamics of wood stoves air circulation seems a huge issue on this forum and there are lots of knowledgeable people on here. However in the 10 or so threads I have read on here I can't quite find an answer to my question, so I was wondering if anyone who has a stronger grasp of physics might be able to help me...
Basically my problem is all my heat goes upstairs leaving downstairs much cooler and there's no real way to block the stairs off. I know this is just because of the laws of physics, less dense hot air rises - but is there any way I could use fans of some kind (preferably pedestal/box/tower rather than ceiling, but I am open to suggestions) to help air circulate better and avoid the upstairs (hot) downstairs (cold) temperature differential? Do you have a fan upstairs blowing air upwards to move the hot air around, a fan upstairs trying to blow air downstairs or even one in the colder room blowing the cold air upstairs (if that's even possible - maybe would just move hot air up quicker?)
Thanks in advance...
What is the ceiling like, all one level up to the stairwell? If so, creating a false transom to block the flow along the ceiling can help reduce heat migration upstairs. I did this in our house with good success. The ceiling was flat before I added this and the wood stove heat would head right up the stairs. With this block, it has more resident time in the living and dining rooms.
Also, check upstairs closely for air leaks. If air is leaking through poorly sealed windows, attic vents or stairs, etc., then that will create a chimney effect, pulling the heat upstairs.
You or someone else can n your family may not like this solution but I will throat out there. Clear vinyl strip door and clear shower curtains. They do not meet to go all the way down but far enough to keep a decent layer of warm air from going up the stairs.
The air "stratifies" (layers) in the warm room, with indeed the warm air at the top. So the hottest air is the air that goes up first, because it moves easiest (least dense) and because it's first in line to get there.
Therefore, one step that may help is to mix the air (decrease its stratification) in the warm room. That is best done with a ceiling fan.
A curtains to somewhat close off the path to upstairs might be considered if possible.
If you have multiple rooms upstairs, keep all the doors closed (so that only the landing gets the heat).
Blowing down warm air from upstairs is likely going to be least effective, because it won't be as hot anymore, and making it flow is going to make people feel colder. (I.e. it has cooled down to a few degrees above what you want downstairs, so you'd have to blow a *whole lot* of air down the stairs to move enough BTUs down the stairs because the heat content of "slightly warmer" air is not so high - and blowing a whole lot means people will feel the wind, making it actually feel less comfortable. That's the same reasoning as putting your AC to a bit higher temp and adding a fan in summer.)
So, prevention is the key, not mitigation of heat that has escaped upstairs.
Better suggestions might (...) be possible if the layout of the spaces is provided.
Begreen's suggestions are very helpful too in preventing this from happening.
Reactions: Corey
How are you heating the house? If forced hot air, do you have returns? Keeping the fan running can help circulate the air. With a boiler, are you on a single zone? Do you have a gravity fed system or a circulation pump? A ball valve can sometimes be installed to control how much hot water flows through a loop. Part of your issue could be simply too much heat being directed upstairs.
Could changing the thermostat location(s) help by running the heat less?
Reactions: Corey
Lots of valuable info above. As EatenByLimestone said, if you have any type of heating which can be 'zoned' - that certainly helps. I used to live in a 2-story town home and it was a bi-annual task to open all the air vents upstairs / close all vents downstairs so the air conditioner could keep the upstairs cool and the downstairs naturally stayed cool. Then reverse for the winter so the furnace could heat the downstairs and the upstairs stayed naturally warm.
If you don't have that, then as stoveliker said anything which can help break up the 'hot' air stream, or even things like closing doors upstairs can help stop the hot air from rising up there.
Thanks. It's completely open plan (downstairs has a kitchen/diner and living room, partially separated by an interior wall but with no door between the two rooms. The living room has the stairs in it, leading directly up to a small landing where the bathroom and 3 bedrooms are located, all with doors thankfully so I can at least close them off) so I am not sure a false transom would work (nowhere to reasonably put it!). Good to know that blocking air flow across the top of the room might help, maybe I can come up with some way of thinking that through...
Regarding leaks almost definitely - I need to weatherproof the window at the top of the stairs (which is great for light, but probably not so great for avoiding a chimney effect) and change the hatch to the attic (also at the top of the stairs) to one that's insulated I think.
Might end up feeling a bit like an abattoir! But thanks for the suggestion. What other kinds of materials might work? I am guessing thermal cloth curtains might do the job, would a bedsheet or something less permanent have a noticeable effect do you think?
Thanks for the explanation of air stratification. I suspected when posting this that prevention might end up being the answer, but good to have it confirmed (and some tips provided by you and others). I could feasibly put some kind of curtain on/around the stairs, not sure my partner would go for that though.
I am in the UK where we don't tend to have any kinds of fancy heat circulatory systems in our homes - it's a classic steel radiator in each room powered by a gas condensing boiler. Excluding the landing at the top of the stairs which has no radiator. I could certainly move the thermostat up into that space and maybe set it at slightly higher than I would want downstairs to be and see if that makes a noticeable difference? I suspect it would just mean the heating cuts out around the same time though. In all honesty I find downstairs being too cold worse than upstairs being too warm.
As above, sadly no vents whatsoever in this home (unless you count the leaky windows and walls...). As you and others have said, I think maybe the 'breaking up of air flow' is gonna be the best option. Thanks for the suggestions though!
Ok. Steam boiler or hot water boiler?
I’m not too familiar with steam. Easy way to tell steam from hot water is 1 pipe going into the radiator for steam and 2 pipes for water.
If water, it could be a gravity fed system, in which natural convection moves the water. There’s a valve to help balance these systems on the bottom of each radiator. Or you could have a circulator pump operated system. On a circulator pump system you may have multiple zones that may have valves to act like dampers and control heat to the upper floor. You may need to map out the system to figure it out.
It’s probably going to take multiple approaches to seal the problem. The good things is, after you run through them, your heating costs will plummet. The heat won’t escape as easily.
Definitely water - it's a combi boiler so not gravity fed. I do have TRVs and try to balance them so upstairs on a much lower setting than down but ultimately heat still rises.
Can you put a half door, or solid gate at the top of the stairs? My thinking here is that in order for warm air to rise up the stairs, cooler air has to come down...if you can block things off say 42" high, then that blocks the coolest of the air from falling down the steps...might help some?
If a door at the bottom of the stair isn't practical, why not a door at the top? We have five staircases in this house (used to be six, one was removed), and four of them have a door either top or bottom. With regard to controlling heat loss to the floor above, both work the same.
Regarding the attic hatch, yes to insulating that. But YESS to air sealing it. Even an R50 insulated hatch that slightly bends easily creates a quarter inch gap thru which a lot of warmed air disappears.
Insulation and air sealing are two different things - doing only one is not going to give satisfactory results.
Can you post some pictures of the stairwell that include the ceiling area around it?
Yes, insulate it with some dense foam board and gasket it so that a seal is made on closure.
One other thought just occurred to me.
My house spent most of its life as a single story house. I only finished off the attic 10 years ago or so. I have insulation between my 1st and 2nd story. Not much, only a few inches was blown in, but it does make a difference in slowing heat transfer.
