Hi all, long time lurker, first time poster. I currently have a VC1280 and an Osburn 3500. I inherited the VC1280 through the house purchase, the Osburn was my choice. Truthfully, the VC1280 is a good unit, when run hot, it puts out the heat I need BUT I have to wake up in the middle of the night to refuel. It does not do low and slow well, and with its limited capacity, just won't put out the heat I need. I can get an all night burn in the Osburn however it just puts out too much heat when its not quite so cold. I can choke it down more but we get into a not so efficient zone and I'm getting a steady stream of smoke as the secondary burn just isn't happening.
I'd love something like the KE40, I could stuff it full of wood and let it do its thing all night and maybe even longer. I know the princess exists, but I'm greedy and want the extra burn time/capacity.
Has anyone installed a KE40 inside a firebox? I've got the room, its 41W, 29H and 21D" as well as about 16 inches of hearth. I'm not concerned about the appearance. I know there are clearance specs for the unit, however sitting inside a firebox seems to negate those as some units can be run as a stove or insert.
*worth noting is the VC1280 has a 6 foot of 8" pipe up to a metal plate that connects to the clay flue inside the chimney. I'm hopping I can just connect the king to this setup.
