Hi! New to forum and relatively new to pellet stoves. We bought a house in 2019 that came with a king 5502m. It has worked great since we got the place, just put in pellets, clean, and enjoy - had to replace igniter last year but that’s it.
This year we fired it up and it ran for a bit then shut off and threw an error 2. There were plenty of pellets and I made sure there were no jams in auger feed and started it up again, it lasted about 10 minutes then smoked so I shut it off.
Now when I try to start it the draft fan goes, it feeds pellets, the igniter goes, the pellets catch. Then the draft fan shuts off, it keeps feeding pellets and burning, and what sounds like the room fan tries to kick on. It spins up for a second then shuts off. It keeps doing this and left for many minutes it never stays on. The pellets will just burn and smoke and draft fan won’t come back on.
What am I doing wrong??
I tried putting in test mode and it passes all tests including the room fan which will run on test mode as long as I let it.
I’m at the point that I’m just going to start placing things, I just redid the door gasket and that did not fix it, next will be glass gasket but I don’t think that is the fix.
Any help, insight, suggestions, or follow up questions would be appreciated!
Thank you
Nathan
Thank you
Nathan
![[Hearth.com] King Pellet not starting [Hearth.com] King Pellet not starting](https://www.hearth.com/talk/data/attachments/286/286592-455895b40d9545b47d13df0a08fb8c25.jpg?hash=kg6GPmKpq1)
