I am having trouble too with basically the same thing and thought about the fuses.they look good but who knows.is there certain brand or regular buss fuses?I'm having trouble with my stove reading error code 8 and shutting down. Stove is clean, fuses are good, and I just spent $400 replacing the room fan motor. It's still doing the same thing. Please help! I'm freezing?
Hi, Metermaid2. I checked my fuses with a multimeter and all showed continuity. I looked at each circuit comparing the room fan to the auger and exhaust and they seem to show continuity for the most part. I think there may be diodes or other components that make it difficult for me to prove the whole circuit out from beginning to end. I know a little about electronics but even this simple board is past my experience. I want to check wire harness to make sure the wires to the room fan is not pinched or grounded but it may be a mute point because the fan runs well in test mode. I keep thinking it must be a processor on the board. Jason Munson from California repairs boards for $250 but he charges that if he can fix it or not. The cheepest new board I found is $350. I would spend the money if I knew a new board would fix the problem. I was hoping I could benefit from the solution the originator of this thread used. Right now the stove runs well with a 5500 model board. It's 27 degrees out so having the stove going is making it hard to shut down to troubleshoot more. Maybe I answered my own question. The stove runs with the old board. By means of pluck and chuck, it looks like the board.Should be a 5amp 120v/250v fast blow
I missed your model number 5500m. The model I have is a 5502m. If you think it may be the fuse switch fuses with another circuit like the exhaust fan and see if the problem follows the fuse. If it does that would be a cheep fix.
Hi, I see this thread is from November of 2018 and I'm hoping by now your problem was resolved. I have the same problem with the same model stove. The room blower goes through the test mode fine and runs for as long you let it but when the stove starts up and the room blower starts the stove goes into a shutdown mode. The motor seems fine but I'm not sure about the board. I had a model 5500 and pulled that board and installed it in the 5502m and the stove runs fine but I'm not sure all the safety circuits are right. The igniter circuit is different and I don't use it. I had the stove for two years before hooking it up and the warranty expired so The company won't help. I was thinking about getting the circuit board repaired or buying a new board but if that's not the problem I'll be out a lot of money but still have the same problem. Did you have any success in solving this problem?
On the lastpage of my stove manual there is a wiring diagram. In the center of the diagram the main pcb is labeled. The drawn representation shows the positions the wires should be plugged in.the molex connector is shown at the top so you can get the proper orientation. The circuits are labeled on the board and the steaks are also labled. The molex plug is prewired and only goes together one way. If you don't have the manual, I can give you the wire colors and the terminal locations.sure wasn't hoping to hear that.You all are very informative on here.and have gotten a lot of feedback.I guess have to help each other cause the stove company wont.Pretty sure I hooked up everything right on control board when I pulled the room fan.where can I get a actual diagram of what leads goes where
You put the wires on the same spades the old was on? it shouldn't matter which wire AC don't care. As long as they went back on the same 2. Can you post a picture of the board and connectors?
