Unfortunately, I am having the same issues with my new Kuuma Vapor 100...I've had this thing hooked up and operating for about 3 months now...Professional HVAC company installed and ducted..the whole 9 yards...a big production....I'm in Tennessee, so VERY mild winter weather. The Kuuma operates and heats the house GREAT when outdoor temps are in the 40s...When outdoor temps drop into the mid 30s, the Kuuma still keeps the house "kind of warm" at about 67 degrees..Yes, that's with the firebox blazing away... I researched wood burning furnaces for over 2 years, and carefully decided the Kuuma was the way to go...This was a VERY big investment for my family. My house is 1900 Sq. Ft. one story living space, ranch style house with a full basement. Nothing exotic. Big tall chimney as well. Oh yea, the Kuuma itself operates as advertised..Stack a bunch of nice seasoned hard wood in the fire box, and it gets HOT! The problem is, this heat is not transferring into nice warm air in the house..Today, the temp outside is 26 degrees (I know, 26 degrees is child's play compared to all of you in the Northern regions and Canada) but for Tennessee that's cold And the Kuuma still can't get my living space above 64 degrees
I "guess" it's the fan moving the air too quickly past the heating area just below the plenum because cold air is blowing through my floor vents...It's embarrassing quite frankly.... I know the stove pipe is hooked up correctly and the smoke runs out the chimney clear as glass, so even if this thing needs to be adjusted here and there, I do not see how I will ever get consistent 70 degree indoor heat from it..I just don't think it will happen. I can't find any reason why this thing can't produce heat in my house above 64 degrees on a day when it's 26 degrees outside....I guess (when I get the time to deal with it) I'll have the HVAC guys come out AGAIN to scratch their heads and offer little solutions...I do feel like to a large degree I have a very expensive paperweight that will at least keep us from freezing to death if the grid goes down...Word of advice, I just feel there are too many variables involved when trying to heat a home with a wood burning furnace...there are too many variables to take the gamble if you're looking to heat a home with this thing and no house/chimney/draft/ducting etc. are created equal. Results WILL vary from house to house for certain with these furnaces and that is VERY problematic. I know the folks that are getting 77 degrees inside their houses when the temps outside are below 0 are telling the truth..I trust the folks at Kuuma 100%, but man, this was a big expense and I'm just wasting beautiful firewood at this point. Thank God I still have my heat pump on my HVAC unit and propane set up. Serious advice: If you really are dead set on burning wood for heat, set up the cheapest unit you can, see how it works for you. If you like the results, many then after a few years of saving money, look at getting a Kuuma...maybe you'll have those excellent results all of us read about from satisficed customers...Maybe your house/chimney/ducting, and all the science that goes into this just works for you and your house. Thanks
I'm gonna throw a few questions at you here...
Have you had your HVAC guys out to look things over again?
Have they talked with Lamppa?
Most HVAC people treat wood furnaces like a gas furnace (the ones that will even mess with them at all) but they are two very different machines! Most HVAC guys are totally clueless when it comes to tweaking things and setting up a wood furnace to work properly...and half the ones that think they know, really don't...there is a lot of misinformation out there in regards to heating with wood.
Have you checked to see that the baffles are in place in the HX? That will make a big difference.
What is your draft set at, you said you have a very tall chimney, that often means high draft, which mean a ton of heat lost up the chimney...you need to get a draft reading and make sure your baro is working, and set right...some people that have tall chimneys actually need two dampers. Do yourself a favor and buy a Dwyer Mark II model 25 manometer to leave hooked up all the time...they are not expensive and provide valuable info...I look at mine everyday. Oh, also need chimney type and specs.
Do you have you return air ducts hooked up, or just pulling basement air in?
Often times the air at the floor is 10* lower than the air at the ceiling...just hooking up the return air ducts means the furnace can add temp rise (often in the 40* range) to room temp air (64* in your case right now) instead of basement temp air which is what, low to mid 50's?
Are your supply ducts insulated?
Are you using the thermostat...in other words, is the blower running on high, or low? I find running the blower on high (tstat calling for heat) to be just about worthless.
I assume you are using the filters that the VF came with?
How big was your previous furnace, and how much fuel did you use per year (gas/oil/electric?) In other words, what is your heat load like/how well is your house insulated/air sealed?
Don't lose hope, its sounds like you are on the right track, and believe it or not, once you get things dialed in the VF will heat you plumb outta the house!
