12pc teardown. 4 legs, bolts 5/16-18,3/4l,washers,no nuts. Torched off,tapped out ,new replacement bolts. 3 threaded rods replaced with 2 3ftrs 5/16,washers,nuts. With one orig threaded rod heated to bend hook,cut new rod to length. Wire wheeled old cement from seams 6pcs. light wire wheel touches to leg top/bottoms,bottom inner plate,door hinge/pins,latch. Oil up bolts on the vent wheels to get spinning.
![[Hearth.com] Lange 6303 bought,teardown,rebuild. [Hearth.com] Lange 6303 bought,teardown,rebuild.](https://www.hearth.com/talk/data/attachments/198/198213-1155c0b984f774db60a289f4e3b3c46d.jpg?hash=lTYVyyXxrS)
![[Hearth.com] Lange 6303 bought,teardown,rebuild. [Hearth.com] Lange 6303 bought,teardown,rebuild.](https://www.hearth.com/talk/data/attachments/198/198212-e5070fdde6af458e5704e100b4a6209b.jpg?hash=EotPlUKW4b)
