Liner alignment
OK, so I had the chimney sweep come out. Not sure exactly what to think,m.
He told me that he didn’t think that the angle in which the liner came down into the appliance adapter was too severe. I asked him about why he figured two of the three screws that were holding the appliance adapter into the drawdown adapter had backed out. He said that his best guess was that they may not have been put in correctly at the beginning. He put new screws into where those screw holes were already and added a few more, given that the drawdown adapter has several other Predrilled holes that someone could utilize. At this point, there’s about five or six screws, connecting the appliance adapter to the Jotul draw down adapter.
I think I was anticipating the person to recommend a 15° offset be used, but he maintained that he didn’t think the actual angle that the liner (heavywall) came in was too bad. I’m hoping that the new screws that are in there now aren’t just going to do the same thing that the old ones did.
This chimney sweep is new to me. Has CSIA certification, whatever that is worth. Here are some before and after pictures. The picture which shows the insulation is the after picture.
Thoughts?
  • [Hearth.com] Liner alignment
Thoughts?
I agree...have since the beginning...that angle doesn't seem too severe, and a missing screw is no deal breaker.
Replace it, make it a larger diameter, or longer, if need be. Burn on...but check it again later on just to be sure.
Reactions: Ctwoodtick
I thought the idea of the adapter was to allow for a bit more angle, in order to move the liner away from the damper of the fireplace?
To me that's the more important aspect of this.
If all that fails, and cutting out the damper fails, I'd stuff some rockwool between the liner and the damper. That'll protect it from rubbing (at the expense of some stress that'll likely anneal out pretty quickly).
I hear you and thank you for those thoughts. I know I did recently post about gaining a bit more of distance from the damper frame itself, but more recently I’ve become more concerned with those screws popping out, and if that was a sign of stress based on the angle that the liner is currently. The liner, which is a heavy wall liner, does make some contact with the damper frame, but does not appear to be pressing against it very strongly right now. Aside from that one point of contact, the liner has space all around it unobstructed I actually have to put a shim or otherwise adjust one of the legs of the insert because when I push on the face of the insert, there is a very slight tilt. When I tilt the insert back, I can see that there is about a 1/16 or perhaps a tiny bit more space between the liner and damper frame. It’s difficult for me to describe exactly, but the liner does not appear to be pressing on the damper frame severely.
I had asked the chimney sweep about this exact issue today and he said he thought it would be fine and that perhaps I may get some surface scuffing of the liner. If it were a light wall liner, I would be more concerned, I think, but in any case, I will inspect the liner regularly..
Reactions: stoveliker
Screws would snap if stressed before backing out. I’d guess the screws were installed to the point of stripping and that along with expansion/contraction with heat cycles worked them out.
OK, thank you for that information. The chimney sweep today confirmed that the screw had backed out and had not snapped (I still had the 2 screws in question).
That said, the sweep had put in a few new screws in new spots on that Jotul draw down adaptor and had put new screws into the old screw holes. I believe one or perhaps 2 of the existing holes had some slight misalignment with the corresponding “inner hole” of the appliance adapter. I’m thinking that in perhaps one of those holes, his new screw may have created a slightly bigger hole because of the slight misalignment. If that were the case, would there be much effect? I’m guessing that any small holes down low in the connection would pull air in versus out. What do you think?
I agree, it should be in vacuum at that point in the flue unless there was a blockage above.
If those screws won't tighten, just install the next size larger, they'll likely tighten up then
Like if they are #8's, use 10's...
OK, unfortunately, there’s another wrinkle in the story. So I was looking back at some pictures of the connection between liner, appliance, adapter, and draw down adaptor. In my mind, I assumed that I was seeing rivets of some sort, connecting the liner to the appliance adapter. When I put this picture on AI, it said that those are not rivets and they’re actually part of the appliance adapter construction itself. I cut back enough of the insulation wrap to expose the appliance adapter. It had two holes drilled through the back of it with noticeably missing screws. So at this point, this heavy wall liner is secured into the appliance adapter only by gravity alone.
And of course, the guy that I hired to give me his advice and fix up this issue didn’t notice any of that and just focused on securing the connection between the appliance adapter and the drawdown adapter. I’m beyond exhausted and ticked off at this point with this whole thing.
I can certainly get some stainless self tapping screws and make these connections myself at this point, but I wanted to post this to see what general advice you guys have on this. I apologize about this saga continuing.
A couple thoughts I have at this point- apparently the screws falling out thing is a general trend with this set up for whatever reason, whether it’s the angle the liner comes in at or something else. Also, with the liner and insert currently installed, along with the holes drilled in the appliance adapter being in the back part of the fire box, it’s tough for me to ensure that any new screw that I’d be putting in there would be going through the existing corresponding holes in the liner.
At this point, the planum, thinking of is to secure for good stainless self tapping screws to go through the appliance adapter and through liner to secure. I think the previous installer may have set me up for failure by only using two and only on the backside, I believe to accommodate the lean of the liner.
I would be making pilot holes through both Two make life easier. Please let me know if this does not sound like a good plan or if there is a small pointers you can give.
Believe me, I’m completely beside myself and exhausted with dealing with this.
Thank you for any input
So what did the CSIA expert do and what about the AI concerns of unequal pressure on the Jotul draw down adapter?
The CSIA guy looked things over and added new screws to the existing holes in the draw down adaptor/ appliance adaptor connections . He also added more screws to that connection so he wasn’t just relying on the old ones.
He felt the angle of the liner was not too bad.
He unfortunately missed the fact that the connection between the liner itself and the appliance adaptor has NO screws in it whatsoever. I thought I was looking at some sort of fastener to this liner but AI said that what I was looking at was actually part of the adaptor itself. It appears that there are 2 screw holes on the backside of adapter that have missing screws. I’m not happy with the CSIA guy for missing that.
Going back to AI, my plan is to add 4 - #10 stainless screws to the liner/adaptor connection. If over time those back out as well, I’ll have to do something else.
This is why good liner adapters use a band clamp whether the adapter is straight or a 15º elbow.
It’s so hard to find good help out there. I have a bad track record with competent chimney sweeps. I’m guessing it’s just bad luck and not necessarily a sign that the trade is generally poor. I do wonder about how much training they actually have versus a plumber or electrician.
It forces the homeowner to have to be more knowledgeable about this stuff than they need to be, which is stressful.
I will add the appropriate screws to the connections and monitor. If needed over time, I can call someone to make more significant adjustments. I wasn’t going to do this with the csia guy who just came out though. Nice guy, but didn’t have too much trust in his knowledge base when we were talking.
Another thing that dawned on me is that I just noticed reminded myself that the insert itself is not completely level. What I mean is that it appears that one of the leveling legs maybe uneven because I’m able to push on the top of the insert itself and without much force can cause it to tilt back, perhaps 1/16 of an inch. I’ve never really noticed it before, but I’m wondering if loading the stove over time and opening and closing the door has caused more movement to the insert and the bottom liner connections then should be there, and perhaps causing/exacerbating the tendency for those screws to have backed out. I don’t think I have access to leveling the legs of this insert (Jotul Rockland ) with it being already installed but I will use some noncombustible shims underneath the inert to help minimize any tilting. Then I can more properly screw the liner to the appliance adapter.
What a headache.
