Hey all - I've posted a couple of times over the last 2 years about a stove recommendation for my funky 4 sided fireplace that was already retrofit by a previous owner for a wood stove.  They cut through the damper and installed a stainless steel liner plus insulation in the chimney.
The contractor I hired to repair some cracks in the external chimney and install the new Osburn Inspire stove thought that the existing liner was in decent enough condition to reuse, but when they tried to connect the liner to the stove pipe, it cracked and needs to be removed.
So I now have 3 options that I'm hoping to get some help and feedback on. The contractor is going to remove the existing liner, as well as the existing insulation, and will install either 1) a new liner (no insulation), 2) an insulated liner, or 3) a new liner + wrap around insulation. The costs are 1K, 1.7K and 1.5K respectively.
The installers opinion is that b/c I have a long chimney (~20 ft), the ROI of an insulated liner or liner + insulation is going to be relatively small.
As much as I'd like to minimize extra cost due to this unforeseen circumstance, I'd like to take the opportunity to do this right the first time. For the experts out there, could you let me know what option you would go with and why? Will the insulation only help with drafting and the initial starting of the fire?
I'm including pics of the fireplace and the chimney in the attic. The chimney flue is quite large so I don't think insulation is going to play a huge part from a safety perspective (but please correct me if I'm wrong).
Thanks in advance for your help!
![[Hearth.com] Liner & Insulation Recommendation for New Stove - Osburn Inspire [Hearth.com] Liner & Insulation Recommendation for New Stove - Osburn Inspire](https://www.hearth.com/talk/data/attachments/314/314701-66c3383b4dedea7e2e0523f9f0f8d5dc.jpg?hash=kVnyAZ90jD)
 ![[Hearth.com] Liner & Insulation Recommendation for New Stove - Osburn Inspire [Hearth.com] Liner & Insulation Recommendation for New Stove - Osburn Inspire](https://www.hearth.com/talk/data/attachments/314/314702-195f755e18e9108ebd7279d5f260ef68.jpg?hash=cxrw5MOWIb)
