Since I'm building up my stockpile for my new insert and I'm doing the bucking, here's my dilemma.
1. If I load EW it can hold 24" in the front, but only 21" in the rear.
2. If I load NS it can hold 15". It tapers off in the corners but I could tilt the splits a bit.
What length should I cut at? I was thinking 21". That only leaves 1.5" on either side of my firebox. Plus if I have the odd slightly longer split I'm Ok. I would prefer NS so I could mitigate the off chance a burning split rolls against the glass but is that worth cutting to 15"? If I have a 20' tree and I buck it to 15" pieces that's 16 cuts. That same 20' tree could be bucked to 21" in 11 cuts.
Thoughts ? Thank you to the more experienced than I in advance [emoji41]
