Log splitter valve lever replacement
gzecc
5,131
NNJ
Didn't think it would be hard to make a lever for the valve lever on my splitter. The original one broke at the end where it attached to the bottom bolt.
Not as easy as you may think. It needs a specific curve to fully retract and extend.
Anyone know where I can get one (lever) for a Omaha Brand valve?
how abut welding or brazing it back together? Never heard of the Omaha brand.
Tape/Super glue/Band-aid the old one together and form the new one to match. Shouldn't need anything too complex but pics would be a big help.
Here is a pic. It broke at the lower hole. I have since spent an hour re fabricating it only to cause it to crack again. It works, but it won't work for long being cracked.
  • [Hearth.com] Log splitter valve lever replacement
I'd re-fab it from a piece of flat stock. It'll be much stronger that way, especially if you get a piece that's slightly wider than the original (same thickness so that it engages the spool properly) near the bottom.
Norther tool sells a replacement handle cheap.
20 minutes with a torch (weld/fill) and grinder (reshape/flatten weld) and a drill press (new hole) and you could be up and running.
True if I had a torch and welder.
