What is the longest non-cat burning stove on the market today that you can buy?? I currently own a Wonderwood circulator wood stove which does not do bad, but I am only getting around 4-5 hours of burn time. I would like to find a wood stove that can get somewhere around 7-8 hours at least so I don't have to get up every morning around 2-3AM to put more wood on the fire to keep it going. I know the cat stoves will burn much longer, but I don't want to worry about the maintenance and I have heard the cat stoves can have issues with creosote building up. Any input is much appreciated
Welcome to the forum corey148.
Others have asked about house size and location as that has much to do with which stove will work best for you. I am thinking that your heat needs are not really great if I have that Wonderwood stove pegged right. With that in mind, several stoves would do well for you.
I'd like to touch on your remark about the maintenance and creosote problem you seem to relate to a cat stove. Perhaps you too had heard and read some bad remarks about cat stoves so tend to think negative about them. Please read the following and you will see that those 2 concerns just are not true with a cat stove.
The last time we were in the market for a wood stove we too scratched out the thought of any cat stove. We went to the few stove dealers around here and started asking questions. Decided that none of the ones we visited knew squat about wood stoves and wood. Right there, that is scary...
Long story short we ended up buying a cat stove but from a very well respected manufacturer. Besides, they gave us a 6 month guarantee. If we bought the stove and it did not perform as expected or not enough stove to heat our old drafty home, they would take it back and refund 100%. How could we go wrong? We bought.
There was a short learning curve because the new epa stoves are much different from the older stoves. Thankfully that learning curve is very short. I laugh now because when we first saw this stove we laughed because others thought that stove would keep us warm. I wondered just how that could be because it was so small.
We are 100% satisfied with this stove and never considered sending it back. With our old stove, an Ashley, we were never really satisfied with it because in the dead of winter we had to close off part of the house and even then were never as comfortable as we wished. Not so for this stove! We have not closed off any part of the house since starting burning with the Fireview.
Best point with the stove is we get more heat and stay nice and warm without closing off any part of the house. Second best point is that we have accomplished this even though we only burn half the amount of wood we used to burn. That alone is enough benefits to make it worthwhile for us but there is more.
We read constantly about folks having problems with creosote. We used to with the old stove but have not had any creosote since. We heat 100% with our Fireview. After 2 full seasons of burning we did clean the chimney just to see what we would get. Got about a cup of soot. That was in the spring of 2009. We have not cleaned the chimney since.
What about maintenance? So far we have replaced one gasket (we just were not happy with how it had been installed at the factory). Woodstock not only sent us the gasket but also the gasket cement so we could redo it. It really did not take long at all and that is an easy job. We have replaced the catalyst but it was under warranty.
As far as maintaining the cat, every so often you have to clean the cat. On our stove that means we lift the top lid, reach in with one hand and lift out the cat. I then take it outside and lightly brush it with an old paint brush. Replace the cat and close the lid. It takes anywhere from 2-4 minutes and is so easy a child could do it and do it well. We plan this year on not cleaning it at all through the winter and just clean it when we do the normal summer stove cleaning.
In maintaining that cat, we spend a lot less time doing that than others spend trying to keep their glass clean rather than all that black crap on the glass and soon they can't even see their fire.
Of course this brings the question, what about keeping the glass clean? We usually clean our glass once in the winter or maybe twice, depending on the wood but we do not clean any black from the glass. It is just ash that gets up on the glass so it doesn't even block our view of the fire. We just clean the ash off to make it look nicer.
We wish you good luck. Should you decide to check out the Fireview or other stoves from Woodstock, click on this link:
www.woodstove.com
