You're right, it's not the TF-88.
This is the shape of the rear shield. It's the same as the double door Honey Bear shown below;.
There is also a blower available that hangs on the back at the bottom and blows up the back, and forward across the top. They are variable speed. Blowers are available in black or brown. That stove is really sharp when painted with Metallic Brown Stove Bright. That was an option on the original.
Many had a tag on the pedestal that is only a sticker type with very small print. It takes a magnifying glass to read it. Possibly painted over in your case. There is a removable base type mobile home certified model when used with outdoor air kit. Here's a picture of the bottom of that model;
![[Hearth.com] Looking for a Honey Bear Manual and Hearth requirements [Hearth.com] Looking for a Honey Bear Manual and Hearth requirements](https://www.hearth.com/talk/data/attachments/122/122356-4aa799e967954e9955d4aca01f5a705f.jpg?hash=0AkhrLqjP2)
Convertible legs or pedestal
The base plate doesn't get hot at all. Ember protection is the main thing.
Manuals for pedestal models state;
Hearth Extension or Floor Protector ;
1.) Provide a non-combustible surface to protect floor coverings. The minimum hearth extension area is to extend at least 16" in front and at least 8" beyond each side of the fireplace stove opening. also, the hearth shall extend over the entire surface beneath the stove and at least 10" beyond the rear of stove.
2.) The floor protector shall be made of at least 3/8' thick non-combustible material and must meet National Fire Protection Association, Uniform Mechanical Code, or local code specifications. Combustible materials that are saturated with flame retardant are not satisfactory.
Usually the carpet is removed, 1/2" cement board is laid over floor and covered with tile or brick face of choice.
They can also be installed so close to the wall, (with heat shields) you are limited by the single wall pipe clearance to combustible. (18 inch) Double wall is then required for reduced pipe clearance.
