I agree with you on all points. I was just pointing out that ducting can be done also if the stove is made for it.Could be wrong but the stove looks homebuilt to me. It's also unclear what the OP's future plans are to get heat up from the basement, thus the cautionary note. If the desire is to still duct the heat then a wood furnace would be a better idea. With the uninsulated walls up to a third of the heat produced by a modern stove will be heading outdoors through the walls.
Not trying to give you a hard time. We want you, and everyone that reads this thread in the future to be safe. On that note, in many jurisdictions floor vents need fusible-linked fire dampers. Check with the local inspecting authority for your area.Just shy of $8,000 for a new stove and chimney work all said and done.
The juper cables are for the blower.
The stove is homemade, it currently heats the house pretty well. Just burns out fast. Im not sure if I really loose much heat due to the walls.
The plan is to have a wood stove heat the basement and radiate up through the floor. I would put 4 vents/pass throughs in the floor so the heat can naturally rise.
Tough crowd you guys are.
Not sure if I can get 36" the ceilings are only 6.5'. The already existing duct work is right in font of the chimney. So I only have about 5' ground to duct where the stove pretty much HAS to sit.If you relocate the flue entry point, go for the stove you wanted in the first place. Just get 36" of rise from top of stove flue collar.
How do I make it code. The furnace hasn't been used in 10 years. I have no clue which vents do what, have three in this room two of which will be within 10'...That will be much more efficient. More heat and much less wood consumed. The heating success will depend on how open this room is to the rest of the first floor and stairwell.
Note that looks like a return air register. If so, that is a code gotcha. It is supposed to be at least 10ft away from the stove. Not a show stopper but a consideration for inspection.
Well I would follow the ducts in the basement and see if they are supplies or returns If you never use the furnace you could always disconnect the duct work from them and patch the holes if any of them are returnsHow do I make it code. The furnace hasn't been used in 10 years. I have no clue which vents do what, have three in this room two of which will be within 10'...
And that would be code if so done deal, the furnace is never used.Well I would follow the ducts in the basement and see if they are supplies or returns If you never use the furnace you could always disconnect the duct work from them and patch the holes if any of them are returns
Yes it would be to code if you closed them off. Also if they are supply ducts there is no problem at all.And that would be code if so done deal, the furnace is never used.
That is what it looks like to me yes but its hard to tell from that picIt seems to me that the circular ones are the cold air returns, correct? The one off to the left is the actual heating part?
Which side has the burner under it? That will be the supply side. If you pull the access cover on the other side it will have the blower and filter in that side it is the return side.Is there a way I could tell?
The returns can usually be told from the supplies by the vanes. Supply vents usually have a damper with a little handle that allows you to adjust the flow. Return grilles are unrestricted. Sounds like you have it figured out. Now may be a good time to look for a freestanding china cabinet .How do I make it code. The furnace hasn't been used in 10 years. I have no clue which vents do what, have three in this room two of which will be within 10'...
