Looking for firebrick source
Sounds about right. Also check your local lumber yard and masonry supply stores.
I built a masonry heater and did research on firebrick - they aren't all the same. In general they come in 3 major duty status grades - low duty, medium duty, and super duty. Generally, the 3 grades have differing amounts of metal (alumina) in them - low duty 20-30%, medium duty 30-50% and super duty 50-99% alumina. The more alumina the higher the grade. Usually the higher the grade the more expensive.
The higher grade, super duty brick are heavier/tougher - they won't chip and fall apart as quickly as a low duty brick. But some believe the higher duty bricks aren't as good in wood stoves because they don't like to be heated up and and cooled down, heated up, cooled down, etc....
They like to be heated up and kept hot like in a kiln. In a wood stove the hot cold cycling may cause micro fracturing but this is in dispute. The lower duty bricks have more sand content which some say is more suited for the hot/cold cycling. But I believe the higher duty bricks are better for all applications but a waste of extra $$$ for things like wood stove liners.
So low duty or medium duty are fine for wood stoves because the stoves really don't get that hot. Unfortunately you live on the West Coast so you are probably stuck with fire brick made by Mutual Materials. These bricks are so-so (most masons avoid them if they can get something better). Better bricks can be had from Pennsylvania/Midwest area - Alsey Refractories & Whittacre Greer. And the clipper DP bricks are good but expensive.
I used some 95-99% alumina super super duty brick in my masonry heater's firebox. Man they are tough and heavy, like 15 lbs per oversized brick. It was like cutting steel. I'll get to see how they hold up/perform.
[Hearth.com] Looking for firebrick source
You have seen different quality stove bricks? These would only be 1-1/4" thick.
Those would be brick splits. Yes there is a difference between brands due to how they are made and the contents. Here is a discussion from the masonry heater association between people who know a lot about firebrick.
Interesting Firebrick Discussion
with (broken link removed to http://mha-net.org/docs/v8n2/docs/www.rumford.com)
The following is a slightly edited version of a discussion on the Yahoo
(broken link removed), about firebricks:
To: MHAmembers(at)yahoogroups.com
Date: Wed, 17 Sep 2008 17:44:05 -0400
Subject: [MHAmembers] High-duty vs. low duty firebrick
Will high-duty or low-duty brick last longer in a firebox? It
would be really nice if there were some more or less definitive
answer to this question, yet it seems that there is not. On the one
hand, we have Albie and Heikki saying (20 years ago, in their book)
that the commonly available low-alumina, low-duty brick will better
withstand thermal cycling/thermal shock better than high-duty, and a
conversation I had with the sales manager for Mt. Savage seemed to
confirm this idea. And there are no doubt many 30 year-old heaters
out there built of low-duty brick that are still doing fine.
On the other hand, a number of experienced heater masons seem
to be using high-duty brick for fireboxes lately, and that is what
Albie uses now too, as a 2" replaceable liner (though that may be
because you can only get a 2" brick in high-duty). Have people been
using high-duty brick long enough to know how long they will last?
What do the Austrians use?
Perhaps the answer is "nobody knows which is better", or
perhaps the answer is "it doesn't matter much, especially if you make
your firebox and throat replaceable". In any case, I would welcome
anyone's thoughts or experiences with this question.
PS "Low-duty" in my case means Whittaker-Greers.
--Steve Paisley
Archimagical Structures, LLC
Ithaca, NY
At 3:52 PM -0400 9/18/08, Norbert Senf wrote:
Hi Steve:
This topic will undoubtedly have many opinions.
Duty rating is based on temperature limits. These don't have
much applicability in masonry heaters, since temperatures are low by
normal refractory standards.
Of most interest is spalling resistance. One way to determine it is
from manufacturer's data sheets, which gives spalling loss in a standardized
ASTM test. You can do your own version of an
accelerated spalling test by heating
a brick red hot and dunking it in water, and seeing how many cycles it
can withstand.
Here is some quick info from Google:
http://heatkit.com/research/fbrick01.jpg
(snip)
Best ....... Norbert
Date: Thu, 18 Sep 2008 16:01:13 -0700
Subject: Re: [MHAmembers] High-duty vs. low duty firebrick
Interesting topic.
We sell a lot of Whitacre-Greer firebrick - as well as Alsey and I-XL. In our Western markets Mutual, Muddox and Pacific Clay firebrick is available so we are familiar with them too.
I use the word "firebrick" loosely. The old ASTM C27 standard that differentiated between low, medium and high duty firebrick was withdrawn by its sponsoring committee in the early 1990's. In it's place was established C 1261 Standard Specification for Firebox Brick for Residential Fireplaces which is a less stringent standard than C 27 was. C 1261 only requires a modulus of rupture of 500 psi and a pyrometric cone equivalent (PCE) of 13.
Alsey makes the best firebrick available. What they sell for fireplaces meets the old C 27 standard for medium duty firebrick. They don't even make a low duty brick or a "Firebox Brick for Residential Fireplaces". Whitacre-Greer and I-XL firebrick meet the C 1261 standard. Mutual, Muddox and Pacific Clay firebrick don't even meet C 1261 but maybe that isn't even important. Interestingly I-XL used to sell a red firebrick that we found performed better than Whitacre-Greer firebrick but the I-XL red brick only had a PCE of about 8 and so I-XL stopped selling it as firebrick.
I agree with Norbert that PCE - or the temperature at which the brick melts - is irrelevant. The practical tests he suggests sound reasonable but I would suggest that how much a brick expands when heated is the only relevant or important characteristic. Residential firebox brick fails by cracking or spalling due to thermal shock. It doesn't have to be particularly strong and it doesn't have to withstand temperatures of more than 1800 degrees F. What's needed is a limit to the linear expansion when heated in order to describe brick that actually performs well as residential firebox brick. And that is my answer to the question about whether low duty or high duty firebrick performs better in a heater. The difference between low and high duty firebrick is basically the PCE which I think is irrelevant. The best brick for a firebox will the the brick that expands the least when heated up to 1800 degrees F.
Another interesting tidbit is the difference between dry pressed and extruded brick. Most firebrick is dry pressed but Muddox makes an extruded firebrick that performs differently. Muddox firebrick seems to do okay when laid as a shiner with the grain perpendicular to the firebox wall but it tends to spall when laid as a stretcher with the grain parallel to the firebox wall.
In summation, firebrick is promoted but not actually required by code but we are all interested in which brick or stone performs well in a firebox. I'd like to see C 1261 revised to include linear expansion and lower or eliminate the PCE requirement but, until then, maybe we can come up with a list of brick that, in our collective experience, does perform well for firebox construction.
Best,
Jim Buckley
Jim added the following comments in relation to a discussion about unfired (green) firebricks:
Date: Thu, 25 Sep 2008 20:27:12 -0700
Any brick, including firebrick, is fired carefully, varying the rate of temperature increase through several quartz inversion levels, to a specific temperature, usually over 2,000 degrees F, determined to be just right for the particular mix of clay and/or shale the brick is made with. Brick manufacturers spend a lot of time and money buying computer controlled kilns and testing their clays to get the brick to have the optimum characteristics while using the least fuel.
Using green, unfired brick, to build a heater and count on firing it in situ is not a good idea. Very likely you'll never get it hot enough - firebrick is fired to about 2,300 degrees F - or you will get it too hot too fast through one of the quartz inversion levels and it will explode.
Modern refractories are a good thing. Build your heater fireboxes with firebrick or castible refractories, perhaps with an insulated backing, and then build the enclosing heater body walls with any stone, brick, rammed earthen block or concrete you like.
Jim Buckley
Jim Buckley
Buckley Rumford Co.
1035 Monroe Street
Port Townsend, WA 98368
360 385 9974 fax 360 385 1624
www.rumford.com
Wow, that's way too much info to read through for stove bricks!
You should be able to buy standard replacement bricks at your local hearth shop. We always have a few thousand on hand for $2 a piece. There's no need for anything special here.
ACE Hardware stores stock them too.
LOL...
The internet, making things more complicated than they need to be since the 90s.
If I was replacing firebrick in a wood stove, I would find out the brand name of the firebrick at the hardware store. Where is it from? I would look at the spec sheet on it. Look for composition - it will have 4 or 5 main things. Look for AlO3 (Alumina) %. The Alumina % will tell you how tough the brick is. If it is 20% its wimpy (you'll be a return customer). If it's 40% it's tougher and will last longer. If you really want the best brick for your buck and you live in the Midwest call Alsay Refractories and locate a distributor near you.
Probably masonry heater builders are a little neurotic about their firebrick since they use so many of them, and the quality of the brick is so important for function and longevity of the heater. Good bricks can stand the test of time while the imposters crumble away.
Reactions: Pterodacctil
yeah we can get 3 different grades at our brick yards. We can get 3 different colors to white yellow and red. But we have the lower 2 grades available in splits
WOW. Thanks for all the info. I like stuff like that, I'm a mechanical engineer. I plan on reading the whole thing tonight.
I called the local Ace. They want $6.49 each for firebrick. TSC is a better deal. I checked their web site and they give no compositin specifications on their brick. I'll try to see if I can find out more if I look at the bricks myself. Maybe the packaging gives specs of a manufacturer I can call.
Thanks for the info. I'll still look around for a source other than TSC too.
Believe me, there is no need for anything special, any bricks you can source will work fine.
There is definatly a difference between the grades we typically use the mid grade ones
I got mine from a pottery supply store full of hippies. I think they're Smithfield, 2100 degree. 3" thick was available
when my stove needed a brick or two, I had to find pumice type of brick to match what the manufacturer used. It's easier to cut and drill, extremely lightweight but pricier. I guess they were considering the insulation properties of the brick when designing the stove.
