This is my first post! I currently have a king wood coal circulator. It's worked good for us for a good while we want to upgrade to a wood furnace. Main issues with it is it takes up a large space in our already small living room and it creates a mess with bringing in wood. I have a basement with chimney access ide like to set up a wood furnace down there and keep the mess on the concrete floor and be able to heat our home thoroughly we have a 1200 square foot house.
Growing up we have a royal wood furnace that seemed to work well and my father still uses.
I have been reading on these epa stoves? Is an epa stove the way to go? Do they really use less wood? I do not heat 100 percent on wood it's more of a supplement heat for really cold times I live in central indiana.
Looking for advice and whatbstove would be best epa stove or good older stove
Thanks
Thanks
My LP furnace blower and wood furnace blower can both run at the same time if ever needed. For example, if we ever have some crazy long term extreme cold weather were the wood furnace can't maintain house temp, I can set the LP furnace thermostat to whatever temp I want the house at and my LP furnace will kick on/off as required in order to keep the house at the specified temp, all while the wood furnace is doing it's thing. I did not want a heating system where I could only run one or the other. As I also wanted it idiot proof and functional in the event the LP furnace was ever turned on by accident while I was away when the wood furnace was running.
Chimney is were I'm gonna start. I've got the origional brick 1930s chimney ! I lined it with stainless to the living room, its 6 inch. I have another brand new 6 inch liner the company sent two by mistake and let me keep the second because I was honest and called them about it. So in theory if I can get a quality stainless connector I can have stainless in the basement for little to no money. I cant recall the brand but the liner I have was not cheap and is meant for my purpose.
