Hi,
I'm new to the forum. I couldn't find any good info with a google search and have always found forums to be an excellent source of information, hopefully this is an appropriate forum for my question.
I have a Lopi wood stove insert. It works ok, however, when I wake up in the morning it always has a lot of fuel left at the back of the stove that I believe if it had burned during the night would have kept my house closer to my desired temperature.
As far as I can tell there is only one hole for air inlet at the front and center of the stove. One time to do a through cleaning I took the firebricks out and saw two plugs in the back on the bottom (one on each side). Are these possibly another inlet?
If the plugs aren't another inlet is it possible to mod the stove? I am a proficient welder and would be comfortable welding some tubing to the front inlet hole and routing airflow throughout the stove, but it seems like there should be an easier solution.
Any suggestions are appreciated.
Thanks!
Thanks!
