Hello,
My wife and I are embarking on the build of our custom home. We have a lower floor/basement that is approximately 1500 and an upper main floor that is about 1700 sq feet. We have a chimney from the basement to the roof with room for two stoves, one on each floor.
A few questions:
Can the basement stove be used to heat the upper floor? If so, does it need to have a rating of about 3000 sq feet to cover the total of the basement and upper floor?
The Lopi options we are looking at are the answer and the evergreen or endeavor. The answer says it doesn't include a bypass damper; this seems like a necessary feature, why is it missing? The evergreen and endeavor are practically identical stat wise to me and the main differences are mostly cosmetic that I can tell, is this true?
When looking at the heat capacity of, for example, the Answer, it says 1400 sq ft. Is this likely to be adequate enough for a 1500 sq ft floor, or does the heating capacity need to exceed the room size?
Thanks in advance!
A few questions:
Thanks in advance!
