Lots of wood but.....................snow
realstihl
525
eastern kansas
I have lots of wood but can't get to it because snow is about a foot deep. I'm down to about 2 days worth now. With the forcasted snow and cold -13deg It's going to be tough. Last time I checked the ground wasn't frozen under the snow. Anyone else having problems?
Why would a foot a snow stop you? No boots? Duck tape around your pant cuffs and go get it. It only really gets tough going when it's waist deep.
Ditto. Woke up Christmas AM with a three foot drift from the back door to and around my pile. Winds a blowin. I have a blue tarp cover that has bungy cords around concrete blocks holding down my access area. Wind pulled the blocks four feet towards the pile allowing snow to blow clear to the back of the pile. The next two days I just backed the wifes Envoy up to my shop where my main piles are stacked. Loaded up the back and then pulled into the garage. This was kind of nice. I also have 2-3 cords up in the tree line that I need to get moved. And just like you neighbor the ground is not frozen below the deeper drifts.
Good luck to you.
Brad
You guys are right, I'm a wuss. It's about a 100yd trek though. I had to repair my heat pump the day before it snowed so I kind a got caught with my pants down on this one. Usually the weather man misses by a mile. Not this time though.
Do you have a sled you can pull behind you?
Just hitch up the team and go for it. :)
Ed
Similar problems here, just have to shovel a wheelbarrel path, a little at a time and go get the wood. It' will also warm you up; if that is any consolation!
I got one of those cheap molded plastic sleds with no runners to haul wood in from the stacks over winter snow, and it's about the best 15 bucks I ever spent.
I have one I use for ice fishing. I use a tote to carry wood from the stack.
It'd take a really, really long time to bring down a couple days of the OP's wood 100 yards through deep snow one tote at a time...
Ja, one would be better balanced with two totes.
First, Go wash your mouth out with soap for even saying such a thing. A foot of snow keeping you from your woodpile? I'm embarrassed for you. Now get out there and get that wood.
100 yard haul is gonna get old, even if it's only a foot of snow. Time to think ahead to spring for that small shed-like structure to be built somewhere at or near the door of the house!! Even just a simple little shed roof bolted to the side of the house would do it. It is ok to carry an armload of wood that far for a fireplace fire but not for feeding a stove regularly.
Our 5-cord shed is about that far from our door, hundred yards thereabout. It is a challenge when the snowfall hits 2 feet or more, though the dogs run along and help break path and make it easier. However, I've built a place to keep a couple or three days' worth right up at the house and I refill it whenever the chance comes. I also have a tractor with a bucket so can now carry a bunch of wood right up to the back door and then simply unload the bucket.
Uhhh...won't the tractor go through a foot of snow?
I use the snowblower to make a path to my pile.
When I was a boy, we used to have to carry two armfulls of wood, through 3 feet of snow, backwards, in the dark. :lol:
Naaaahhh.
This is alot of snow.
and it was uphill to boot
Sometimes Mother Nature likes to throw obstacles into your path, but it doesn't necessarily have to stop you. I hope you are able to get some wood soon!
Snowblower? Snow shovel? Nothing to it. How do you get the wood to the house when there isn't any snow?
Both ways!
I solved this problem--I only burn in the summer. And if I use green wood, the smoke keeps the mosquitoes away.
Send out a distress call for DOROTHY AND TOTO!!!!!!!!!!!Last time I heard they were still in KANSAS!!!!!!!!!!!!!!!!!
Been out for the last two hours. First hour was snowblowing a path and the next hour was hauling. I have an old Dayton that is built like a tank so I loaded wood on it between handlebars and motor. Works fairly good about three armfuls. Plowboy enginenewity, I guess. Made about 5 trips, maybe will last until next weekend.
