M55 Convection speed can’t be adjusted in Manual mode
bostonfan49
538
Essex Jct. Vermont
So I normally run my stove via my Lux T-stat and as long as it’s calling for more heat, I can go to the stove and hit the fan speed ( I am on 3 by default) up or down with no problem. Fan speed, Pellet feed and Combustion air all can be increased or decreased and all the lights work.
BUT
If I shut off the T-stat, and start the stove in Manual mode, after the initial start up and Convection fan cycling on. The following happens, I start with a huge M55 Flame, that quickly dies out to just a medium steady flame. Per the lights, I can adjust the Pellet feed and air trim but in either mode it’s hard to tell the difference...But! I can’t get the fan speed to increase or decrease....;?
I was unaware that one can adjust the speed of the convection fan within a given heat level. That speed, at least on my m55, is determined by the heat level. One can adjust the combustion fan and feed rate on the board.
Reactions: bostonfan49
So on the control panel (my mistake) thank you ohbix! I meant the Heat Level 1-4. Can’t raise or lower in Manual, but can when it’s on the t-stat.
Bill
