Hello,
I'm a fireplace renovation newbie and could use some advice.
I have a Majestic Thulman Model No. L36A wood fireplace in my living room. I am currently renovating the living room so the fireplace is nicely exposed (no drywall, no finish floor). I figure this is the time to replace it as the firebrick panels are cracked and the bottom of the unit is rusting through.
My questions are:
1) How do I remove the existing flue pipe? It is triple wall pipe inside a non-insulated chase. Does it have to come out from the top or is there a way to lift the entire length (approximately 12 feet from the flue collar to the chaise top)?
2) What model zero clearance would be a reasonably priced replacement?
3) Do I need to replace the flue pipe with the new firebox?
Thanks! I appreciate any help.
My questions are:
