Makita Dolmar 6421 problem
Highbeam
20,902
Mt. Rainier Foothills, WA
Was having a great day just finishing bucking up 5 cords of fir logs. Only found one metal object and everything was working perfectly as usual with this ex home depot saw that I bought several years ago.
I noticed a nice noise change. It got louder, more raspy. I could see some looseness on the muffler and some oil tar leakage. Stopped. Pulled out the little star shaped hole guards and found one of the two muffler bolts loose and the other completely fell out of the threads. The screw looked fine so I tried to put it back in but it just spun as though the threads are gone. The screw had no aluminum in the threads, they looked clean. With one tight screw I finished the last log and set it down to cool. Now I am missing the one screw that was working. It must have fallen out during that last log.
Do Dolmar muffler screws have a habit of stripping out the head? This saw is an ex home depot rental but appears to have never been opened, it was in great shape when I got it. Those muffler screws were factory tightened.
If those screw holes are all stripped out is this something that can be repaired or is it time for a new P&C?
Here’s a photo I took just before noticing.
Is there enough metal to drill it out and tap it a size bigger? I had my muffler get loose by the time I stopped (finished milling a wide 11’ cut ) the ears with the holes on the muffler were broken out.
Loctite the new screw
I'll pull the muffler and check. The dang cat muffler was smoking hot after bucking that 14' log. I need to clean it and then tear the bar off and the left side dawg before complete muffler removal.
An aftermarket 85cc top end is about 100$. OEM is about 300$. A new chinese 372xp or MS660 is 300$. I paid 275$ for the dolmar about 10 years ago.
It's too bad, I really like this dolmar and hopefully it can be saved.
I have this saw and have rattled those screws out, too. Loctite on reassembly is a must. Unclear is the screw stripped or are the threads in the cylinder head stripped? Don't scrimp on replacement screws - they might look right but they'll lead to problems (tell me how I know this).
I had to have someone helicoil an insert into the head in order to get new threads. It has worked fine. I bought a Hyway cylinder kit to bump my saw up to 79 cc but found a good deal on a new Makita 7900 ($650). Today was my first usage of this saw - I warm to new saws slowly - and you can be sure I'll be checking the muffler's tightness quite often.
The one screw that rattled loose has perfect threads but wouldn’t screw back in. Best case scenario is the head threads are fine and things just rattled apart. I’ll gladly buy two new 1.87$ screws and use loctite! Worst case is completely missing head threads. Might as well try a helicoil at that point.
Hopefully tomorrow I can disassemble to investigate.
Reactions: EbS-P
Helicoil or Timesert with red loctite will make light work of stripped aluminium threads.
If there is enough meat left for a helicoil then drilling and tapping is also an option. Loctite for sure with either solution
While you have everything apart it would be a good time to gut the muffler for the good of the saw.
Then retune for the free flowing exhaust
So I got it apart and things look pretty good actually. The old screw that rattled out will not go back in, I believe the screw threads are rounded or somehow no good anymore since another case screw will thread right in. I cleaned everything and the head threads look as good as any. The piston and cylinder also look as good as new with no scratches or anything. Phew.
I'll need a new port gasket and two new muffler screws. Does anybody have a preferred parts source for these cheap parts on a dolmar?
I have the cat muffler in my hand and in priniciple I would like to modify it all to be efficient and durable but the dang saw works just fine all EPA smog compliant and the P&C seem to be holding up fine. I use the fancy echo oil for premix. I don't even have the carb limit caps removed.
So anybody have a good saw shop to buy these parts from? As you can imagine, out west, the saw shops around are mostly all Stihl.
One more question... loctite for these screws? What type of loctite?
Regular #242 (the common blue stuff) is probably fine. Torque it to the spec in the manual.
It probably gets hotter than heck here at the exhaust port.
I'm not a fan of torque specs when it comes to fasteners this small and with lubed threads. I have an inch lb wrench but think I'll just get it good and tight.
Reactions: Newbie78
Red 272 is for high temp applications. But do keep in mind that it makes a darned near permanent install of those screws.
Reactions: qwee and Highbeam
If it's metric,which i am sure it is.
Get the replacement screws from Stihl.
They have serrations on the bottom of the heads and will hold better that the rest.May not need loctite for them.
You can buy sheets of exhaust gasket material at NAPA and cut your own,I just cut a gasket for a 2005 Blazer from my sheet yesterday.
Thanks folks. I ordered from Jack's small engines. OEM parts. I have some blue loctite to use. Will follow up when it's all back together and running.
Okay, everything went together like a new saw. Used blue “surface insensitive” lock tite. I dribbled a little 2 stroke oil on the piston ring since I may have got carb cleaner on it. That oil made the first start a pita!
It’s weird that theres a metal air deflector that lays against the head and then the gasket and then the muffler. Seems like a pretty leaky connection but it works.
Nice and quiet again.
Guys, I’m kinda looking at a backup saw. Chinese ms660 pro or 372xp pro. I currently only have the 6421 and with dolmar stopping making parts for my 10 year old ex rental saw I would like a backup. Plus, big cheap saws look fun.
My advice would be to buy a saw made in the western world, not a Chinese adulteration.
Dolmar still make fabulous saws (despite Makita's threats to the contrary). If you want a bigger saw the 7900 is a beast and heaps cheaper than the equivalent Stihl or Husky.
The 7900 is a great saw but dolmar is not a brand I want to invest in. I own one and had a hard time finding parts for this thread. Lots of discontinued part numbers.
I would also prefer a real husky or Stihl but for 300$ I can have a 92cc saw. People seem to love them and I’m not a commercial user. There’s no other realistic way I would ever own such a large saw.
Reactions: TomMcDonald
As a big bore backup the g600 seems like good option. Parts even good ones are plentiful. I gave up following their quality control two years ago. If it blows up you have a case and hopefully a crank. G600 is the only one I’d buy based on my previous research. The rest just didn’t seem to be as good.
There’s a good video on YouTube of someone doing an unboxing and re torquing of a g600.
I’d buy on eBay at least they have some buyer protections. $350 shipped seems to be the going price today. I think that’s what I paid 3-4 years ago.
Reactions: Highbeam
I bought the g660 couple years ago. You will need to retighten all the screws with loctite. I was told here to replace the compression release valve with stihl one. Use richer mix 30:1. I use it mainly for milling. The saw is heavy and really sucks gas. If you are looking for a saw for firewood processing only and your logs are smaller than 24”~~~, I would be strongly recommending ms261. That saw with sharp chain will run circles around the g660 and use 1/3 of the gas.
Makita has rung the death bell on Dolmar. Makita is no longer making any petrol powered equipment ( Makita owns Dolmar) Been a Dolmar lifer. Guess I will have to switch brands. Likely Husky as with Stilh I can only get oem parts from a dealer at wallet robbing prices.
Reactions: Highbeam
I made a post earlier but took it down. It sounds like you want a bigger saw than what you already have. But if you just want a backup saw that parts are easier to find on consider the Echo 590 (it isn't a gas hog either). They can be had cheap new or lightly used because people get them for one job or in case of an emergency - lose interest and sell them.
I had a 58cc Shindaiwa and was impressed with it - very reliable, nothing fancy but well made - but a parts nightmare. I figured the Echos would be similar and they are. Parts are easy with these Echos. I found a couple new ones for $300 each. This saw isn't as good as a pro saw, but it is better than a farm saw.
Looking on Craigslist I see a Timberwolf for $250, "... used 3 times, like new....... " Maybe I should call one of my brothers in Longview, Washington (Ranier is right across the Columbia River on the Oregon side). They go over to the Oregon side through Ranier to launch their boat to go salmon fishing. ;) - No, I'm good, no more saws. That is a lot of saw for the price. Look at that bar - it looks new. My bars have no paint on them anymore!
https://portland.craigslist.org/clk/grd/d/rainier-echo-590-timberwolf-chainsaw/7623745377.html
I was out 2 days ago with the Echo 590 and the Dolkita 7900 working on some Lodgepole pine. The Echo held its own with the bigger saw. I'm sure the story would be different in something like Locust or Oak, though.
Reactions: Highbeam
Echo used to make some decent saws at a lower price. They were always easy starters for me. I'd give them a good look.
I certainly get into wood bigger than 24" but that's becoming rare now with log loads. You really think the MS261 (a great saw with great reputation) could keep up with the G660? The engine is almost twice as big on the G660. With the dolmar I can cut 5 cords using way less than a gallon of premix, maybe 1/2 gallon. Gas consumption is just not that important but power and speed is.
Just personal experience. Perhaps the chain on the 261 was sharper….not sure. The 261 is twice the cost but as many here will agree, it is one of the best saws on the market. When you think about it….it is only 300 more. As for the fuel, i too do not care about the actual fuel, it is the refueling😉. Do not get me wrong the g660 has its purpose in my shed, but it is not a go to saw for bucking. Again, just my amateur experience.
Reactions: Highbeam
