The heater is estimated to put out about 25,000 BTU/hr. Up to two 50lb loads per day is the max in terms of input.Any estimates on the rated output?
Yes--it should only ever get warm to the touch. In the pics is the core only. There will be a layer of common bricks and then some one inch stone on the face as well.Way cool. Digging it, I see lots of thermal mass, so will you be able to touch that stone when it's full bore?
That is the frame for the cook top.Great progress. What is the black frame on the horizontal top above the firebox for?
It is real--I pulled it out of a creek that runs through our property.Is the stone, real or a cultured stone? I love the look, I plan on using our creek stone , for my chimney and the outside basement wall ,which would give me the same look.
It uses a 8 inch flue. No cat or secondary tubes. The designer (Alex Chernov) is working on some approvals. The work he has done to measure efficiencies put his heaters in the same realm as EPA stoves. You got the idea--one raging fire for about 2 hrs, and then 12-24 hrs of heat depending upon the heat loss in the house. Check out Alex's site: stovemaster.com Lots of very interesting stuff on there.It looks amazing but that's I different world too me. What size flue does it use? Are there secondary air tubes or a cat? If neither how does it get epa cert? What's the plan, like build a fire and let it burn for 2 hours then enjoy the heat for 12?
Lots of questions but a custom home build is a year away for me and that is one sexy machine
Sent from my SAMSUNG-SM-G890A using Tapatalk
No problems--He emailed the design. Some of the hardware did get banged up in shipping, but nothing that couldn't be fixed.Nice looking project ... stone adds so much! Since Alex is located in Ontario, any issues with importing his designs?
The foundation was 5'6"X6' (outside dimensions) using 10" block. Just as an FYI--the cost for my heater, materials and labor (local mason) will be about 10K less than a Tivuliki.What are your specifications for the foundation? I had a 6' x8'x2' thick foundation poured when the basement floor was poured. My intentions are to build a basement to roof line block , stone , 2 flue chimney about 32' tall. 2 EPA wood stoves would heat the basement /rec room and the great room and house above . But seeing your heater and viewing the website, I need to look into a masonry heater. I had looked into the Tivuliki ,heaters but the 25K price , was a turn off. I'm located in Cattaraugus ,NY, probably not far from you in western Pa
