Masonry Heater Option
Extremebison
58
Yukon Canada
I'm always looking for ways to improve things. As we heat with wood exclusively, with a oil monitor back up. I was looking for ways to improve the heating in our house, reducing wood consumption, doing multiple things with wood, DHW, cooking and baking, longer burn times, just trying in general to improve the way I use wood. This is what brought me to this forum.
I've been reading here just about everyday since I have joined. All over the boiler forum, and the hearth room mostly, reading mostly what others or doing and so on.
I was wondering is anybody here was using a masonry heater? and if you don't have one what do you think of Masonry heaters?
The one I was looking was www.heatkit.com A real good friend of mine has one in his house and loves it.
www.tempcast.com another unit
www.canadiankachelofen.com
Benefits:
-easy on the wood pile
-no temperature spikes
-even heating
-oven, dhw heater available option
-utilizing the wood for max BTU much like a gasification boiler then storing the BTU's for up to 24hrs.
-clean burning
-safe as the fire is only present for 2 to 3 hrs.
-does not need electricity
draw backs:
-there not cheap $10,000 to $30,000
-permanent need a jack hammer to remove it
-does not heat like a boiler system, can't be zoned as a boiler storage system could be used.
Can one think of any other benefits or draw backs using these heater vrs other systems? What or your thoughts on these units. Or they to good to be true?
There are a few very loyal and happy masonry heater folk here. I would love one.
We don't hear from them as much, because these are expensive installations and perhaps because they are pretty trouble free. If you search on masonry stove you will find some nice threads discussing them. Also check out Tulikivi masonry stoves on the web.
Here is a thread to get you started. Maybe Marty S. is online and will catch this thread.
https://www.hearth.com/econtent/index.php/forums/viewthread/47757/
Note that it looks like Woodstock Stoves is going to be manufacturing a competitor in this field:
https://www.hearth.com/econtent/index.php/forums/viewthread/68574/
Sorry for beating a dead cat lots of good info there thanks
Byron
I have a poor man's masonry heater. About 10,000 pounds of cement block and two-flue brick chimney going right through the center of the house, all heated by the exhaust gases from my hard-running stove in the basement.
How well does it work?
I loaded the stove for the last time at 11 PM last night. Temp was 71ºF. Woke up at 8 AM.... house was 70º. It's now at today's high temp of a whopping 33ºF (but sunny) at 3:25 in the afternoon and I haven't even fired up the stove yet. Temp just dropped below the 70º line, and I'm sitting here in summer pants and a tee-shirt. I won't start the stove up until it drops to 68º. That may not be before the big game begins. Back up electric heat gets turned off in October, so it's all wood heat doing the job here. No matter how bad I screw up, the wildest temps swings I normally see in here are from about 67º to 73º. I'll admit, some of the heat comes from the south-facing windows, but even on a cloudy day I get excellent heat retention and boringly stable temps 24/7.
I can only imagine how much better a real one would work.
My friends have one.. I think it cost them around $10,000 to have it built and included in the footprint of the house. The positives I see right away are that the thermal mass will radiate heat for up to 2 days or so which means there you're less likely to have your backup heat source kicking on. On the negative side, I think they work best in a very tight house. The same friends have 24" SIP's (styrofoam insulation panels) in the walls and ceiling. Plus, you have to like lighting fires.. unlike where you keep a stove going, the masonry heater is made to have a fire lit inside of it about once or twice a day or every other day.
I think they are very cool but don't know if I like the idea of burning 1 or 2 fires per day and waiting around for a couple hours after the fire dies to close the damper so the heat doesn't escape. A stove surrounded by a large masonry mass can somewhat pull off the same thing, my keystone is surrounded by brick and it stays hot well after the fire is out.
Byron
Not at all, it's a great topic. If you go forward with this project please document and keep us posted on your choice and progress.
Byron
Trust me . . . this is not beating a dead cat . . . although I thought the expression was beating a dead horse . . . maybe we've used up all the horses . . . I would much rather read a thread like this than see the normal thread that we tend to see over and over again about some person who is having a hard time getting heat from their stove and the wood doesn't light up easily, but they know it cannot be the wood since they were told it was seasoned wood. ;) :)
Some of the installs in the galleries on masonry heater pages are SEXY AS HELL.
drawbacks: You have to have a floor that can support a million pounds of bricks. They take a real long time to get up to temp, and take a long time to expel that heat- so temp swings are not where they show their real value. They are expensive
I would consider an install in a brick arched alcove with heat channels in it that could be blocked easily by moving a brick. Bricks in place, heat spills into room quickly. Brick out of place/open channel- heat is transferred to the structure. I know that one of the values of a masonry heater is that they burn fast/hard and efficiently- that's something that would be lost.
Other bonuses- you can have a cook oven in it.
There are hot-water options, though I don't know much about them.
There are other cool options like boot dryer cubbies, and heated bench areas. Tell me your old lady would not swoon over a heated bench in the winter.
I would swoon over a heated bench in the winter.
Byron
Couple other guys said it, but, no dead cat beating going on.
They are very interesting, most everyone I know who heats with wood, and nearly this whole forum, is interested in them. Very few have them, pretty expensive, and a bit different to run. If we were to build a new house, it would be a very difficult choice between a MH and a Equinox..
Searching Russian Stoves is actually how I landed here years ago..
I've wanted one ever since I learned about them and how they work. I don't ever see one going into my house as I just don't have the right place to put it.
Now, if/when I build my dream home - assuming it is in a cold climate - I'll have one. I love the option to put an oven in it as well.
No problem in my house getting the unit on grad to help support the weight. I would have to remove the floor were I want the heater and pour a proper slab on grad. I'm always up for a challenge.
I think I may order up the core and build the stove myself. Time line for this project may be a couple of years. I have been looking at boiler systems but I don't think I can tackle a boiler system on my own. I can get a core for $6000 and then do all the masonry work myself. Keeping the project under $10,000. Boiler systems I've looked at $20,000 to $30,000 total investment. Also there a lot more complicated.
As for the DHW. I plan on putting the tank upstairs above the masonry heater, allowing it to thermosyhon. To help boast the tank when the stove is fired. I will install a couple of solar water heating panels. To Boast this tank during the summer. Here in the Yukon we have average 300 sunny days a year, so we got a lot of solar to take advantage of. The tank already has electric elements to keep it hot between firing, and when were lacking enough solar.
A wrap around bench would be a nice addition and very functional. Also greater surface area to release heat into the house and a little more stone for storage. A great place to sit on and relax the bones after a long day out snowmobiling and bison hunting at -40C.
I love the simplicity of these units. I don't mind firing a couple of fires a day as a worse case scenario. As all my wood I have is seasoned properly and takes a sheet of news paper to start the fire in my current unit with the split wood I us.
I do plan on installing a oven, maybe try and design a cook top also into the unit. Another savings using the wood oven vrs my current propane oven. Can't do this with a wood boiler.
There is a time lag when you light the fire to actual heating, more then a regular metal stove so to speak. But it isn't that great of a lag as the unit will have a glass front and through this door when the fire is full bore they do throw a ton of heat instantly. I have seen this for myself, or should I say felt the demo for myself.
Our main living area is open 800 squire feet, and two bedrooms upstairs. Just a small log built home in the woods. But we do deal with long winters and extreme cold snaps. I think this unit will solely heat our house and one season we would learn how much to stock the fire box according to the heating demand. Big deal if we over fire we open a window and get some fresh air. We under fire we build another quick fire. Being such a small place I feel our firing schedule may only need be every 24hrs, maybe 12hrs when it's -40C.
I like the fact that these units or bullet proof and if properly built, one it will out live the house, it will be around for generations.
The wood consumption will be lower then what I currently use. To factor in savings of 2 cord a year over 20 yrs. The current price of a cord delivered is $220x20yrs is a savings of $4,400. I don't buy wood but cut and collect myself plus I burn scraps off my mill. But $220 a cord is the going rate at the moment. That puts a value on my time getting wood.
Add in the price of electric for heating DHW and my investment would be paid back in 20yrs this is a conservative estimate but a true return figure. This doesn't include any cooking done on the heater, or replacement value of up grading a wood stove during the 20 yr term.
The money I save vrs a boiler system, I can upgrade my windows, add solar heating to my DHW, and hot tub, for the summer months. I will still have enough left over to purchase 20 cord load of logs delivered to the yard.
One big advantage of doing a wood boiler system is that I could heat my rental units on my property, and my hot tub. But if I convert the hot tub over to solar for the summer that would cut half a year of heating.
This my story, I think I have talked myself right into a masonry heater. Any thoughts on this theory of economics of a masonry heater?
Byron
I posted a link to a core that was really cheap compared to most I've seen in a thread a couple weeks ago. I don't know if you get what you pay for, or if they charge you big time because it's specialty.
Dead Cat, Dead Horse, dead what ever, it's still a dead topic,
LOL
I think getting a engineered core system, is the way to go. Not to cheap out here. These cores or used as the bases it seems, then after one can finish the units as they see fit. Soapstone, benches and so on. I really like heaterkit.com because the have a "white oven" in the unit. This means that you don't build a fire in the oven then scrap the coal and ash out to the burning chamber, rather you just light your fire in the burning chamber and this heats the oven. I copied out of the planning guide the details of this see below. This was the selling point for me over tempcast units.
Domestic Bakeoven
New design optimizes
performance
akeovens are readily incorporated into
Contraflow heaters, and have become a very
popular option in the last few years. There
are two types. In the traditional “blackâ€
oven, flames pass directly through the oven, which is
then ready to bake after the fire is out.
In the “white†oven design that we have developed
for the Heat-Kit, the flames go around the oven
chamber instead of through it. This allows the oven
to be used at any time. The oven floor is
unobstructed, with no throat opening to the firebox,
and the interior remains clean, with no soot or ash
deposits. The closed oven chamber and airtight cast
iron/glass oven door gives helps to retain moisture.
The design has been refined over several years of
trials and feedback from users. Benefits include:
• oven floor is several inches lower, for easier
access.
• oven temperature now reaches up to 500° F.,
and will stay above 350° for up to six hours (see
chart from lab test - wood load for this test was
42 lb., previous fire was 24 hr.).
• we’ve added direct heat to the oven floor.
The oven operates for zero cost, since you are
firing the heater daily to heat your home. It can be
located either front or back. A popular design is to
have the heater serve as a space divider between
living room and kitchen, with the glass firebox
doors on the living room side and the oven on the
kitchen side.
My old Lady? She's a sweet young lady, #1 wife, #1 mother, my best friend.
Yes she would also love the heated bench how do your think I talked her into letting me install one.
Were in our early thirties and live in our retirement home already, thats why I want to make it perfect as we love were we live, and if we decide to sell a improvement such as a masonry heater will only improve the value of our home.
You've got to love this wood heating thing. There are so many options when it comes to wood heating. If you just look into it you can find so many different kinds of heating applyances. Anyway, check out these sort of poor mans masonry heaters. Cool stuff, I found these while searching aroud on the web.
http://www.richsoil.com/rocket-stove-mass-heater.jsp
  • Masonry Heater Option
Good thread!
I wish I knew about Masonary Heaters when I built my home 15 years ago. I would have build my home around one. The cost of an extensive remodel in today's economy is not currently an option for me. But it could have been doable with new construction.
I like my current set up BUT I would love to build a hearth around my stove to retain some heat & it would be nice to have a bake oven attached to my stove. The floor under my stove is engineered wood "OSB I-beams" which spans 20+ feet so I doubt I can add any more substantial weight to it.
I read somewhere about placing sandbags or buckets of sand around your stove to help retain heat but I'm not sure if it would be useful.
well i love the idea why couldnt i add one to my outside "campfire area" putting one in the house isnt an option now but im sure all my ladys friends would be much more comfortable coming over for BonFire night in the fall if they had a nice warm bench to sit on ...
Are we getting into wishful thinking here? :lol:
i think not ... im going to build an outdoor brick oven,, why not build one of these . and while im at it ill add a build in propane grill... yeah im serious .. how bouta wood fired hot tub ok im getin carried away but i gota find some way to burn those uglies i cant split ...... right?
