Does anyone know of a way to acurately measure the CFM of the distribution/convection blower? I would like to know what the actual heat output is in BTUH at different settings.
mepellet said:Does anyone know of a way to acurately measure the CFM of the distribution/convection blower? I would like to know what the actual heat output is in BTUH at different settings.
tjnamtiw said:Take your 8000 BTU per pound average times your stove efficiency times how many pounds you are burning per hour. The real unknown is a realistic, truthful stove efficiency number. Some say that numbers were ''fudged' to meet the government mandate (kind of like auto MPG) but probably 75% is a good number.
To really get a true value, you need a lab. Last year we had a young guy on here who was charged by his instructor at school to figure out the same thing at a local business that was heated by a pellet stove. You don't have the same assignment, by any chance? %-P
mepellet said:tj said:You don't have the same assignment, by any chance? %-P
Haha. No. Just personal assignment. I have a curious mind and just was thinking of a way to figure out the real world heat output.
j-takeman said:mepellet said:tj said:You don't have the same assignment, by any chance? %-P
Pretty challenging assignment! What tj suggests will get you real world close, But anything more is gonna hurt!
Before you even start. Your gonna need the the exact BTU amount of the fuel. The pellet you dump in has a wide range in BTU's. Then you can measure whats expelled in the room and also what is expelled out the vent. Lots of work and figures. Some thoughts below.
Some of the stoves out there have EPA'ed certs that have the actual efficiency for the stove at hand. That's really all you need to know. Use the 8000 BTU value(about average for the pellets out there) figure out how many pounds per hour it will feed to the burnpot. Multiply that. Multiply by the stoves efficiency and you will have your BTUH.
Real world pounds per hour will need to be tallied. The stove actually feeds by volume, Not pounds per hour. So you'll have to actually make the stove think its burning and catch the fuel and weight it. This will also very with each brand of fuel used due to size/density variations.
Good luck and keep us posted.
j-takeman said:I would think you need the input to figure out the output. Correct me if I am wrong?
mepellet said:j-takeman said:I would think you need the input to figure out the output. Correct me if I am wrong?
BTUH = CFM * 1.085 * (Temp out - Temp in)
SmokeyTheBear said:mepellet said:j-takeman said:I would think you need the input to figure out the output. Correct me if I am wrong?
Only for the convection side, that is not the only heat output of the stove.
mepellet said:SmokeyTheBear said:mepellet said:j-takeman said:I would think you need the input to figure out the output. Correct me if I am wrong?
Correct. I am trying to tackle one item at a time here. Measuring the radiant heat would be much harder. I'll be lucky to figure out the convection heat
SmokeyTheBear said:mepellet said:SmokeyTheBear said:mepellet said:j-takeman said:I would think you need the input to figure out the output. Correct me if I am wrong?
I hope that they factored in the slight partial pressure change ;-) .
You however are still faced with measuring the flow rate.
mepellet said:SmokeyTheBear said:mepellet said:SmokeyTheBear said:mepellet said:j-takeman" date="1322884817 said:I would think you need the input to figure out the output. Correct me if I am wrong?
How about an easy way to measure the velocity?
SmokeyTheBear said:I second the suggestion to pour a brew and enjoy the heat.
I haven't had to do BTU calculations since college physics classes. There are tons of on line tools to do most of that these days.
tjnamtiw said:Why worry? Pour in a bag of pellets, pour out a glass of beer, tune in a college game, and stay warm!
Webmaster said:I can assure y'all of one thing.
The efficiency and output are probably less than any amount you are thinking.....
I say this because we usually gloss over many aspects of efficiency. Our fine and advanced car engines, for instance - after BILLIONS of dollars of R&D - are what? Maybe 30% efficient at best - with a controlled fuel.
Best to crack a brew and figure 5,000 BTU output per pound of pellets...if you are lucky.
