quick question guys, i brought a hearth and glass cleaner made by perkins and rutland vermont, says it cleans and conditions. anyway i didnt read the bottom says to not use on tempered fireglass doors. the merrimack isnt tempered glass correct?
Unless you're getting black gunk (which should be addressed with better wood/burning practices)- a paper towel with water, followed by a dry one will get the glass as clean as any cleaner. If you have black gunk- burn hotter and it will burn off.
Then there's no need to worry about the cleaner!
Woodstoves use ceramic- it's much more tolerant to heat shock because of low expansion.
Agree with everything but two points . . . I'm cheap . . . I use newspaper in place of the paper towel . . . that and I thought you were a staunch advocate of peeing on the glass AP.
thanks guys i have been using the newspaper ash trick , according to the bottle it says it conditions so i figured i wouldnt have to clean the glass as much. i just dont want to put it on and reck the glass.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
