In the process of buying a new Hearthstone and the bride is looking to buy me a bday gift. I told her that a moisture meter and/or a metal vac would be good gift. Did some research and the mini-Ligno E/D pin type seems like a decent model.
When it comes to a metal vac, I have no idea....so any input would be great in this area.
While I can tell the difference between seasoned wood and green wood, I want to just use the moisture meter to keep track of how quickly my wood loses moisture, in a given area where I stack it. This way, depending on my readings, I can relocate an area of wood that is just not in an optimal location. Plus, I may have aces to some free Oak, and know that this takes a lot longer to season.
Any advice and input would be greatly appreciated.
Thanks in advance.....
Dom
Dom
" All kidding aside, don't spend a lot on a meter unless you plan to turn you wood into lumber for fine furniture or gun stocks. A $29 meter from Lowes or Home Depot or Harbor Freight will serve you purpose for firewood. Meters are calibrated for Douglas Fur and for temps of about 70 degrees and some come with species and temp correction charts and some don't. Attached is a species correction chart, sorry I can't find the temp correction chart.![[Hearth.com] Moisture meter and metal vac recommendations. [Hearth.com] Moisture meter and metal vac recommendations.](https://www.hearth.com/talk/data/attachments/128/128482-4c86fa055b80a542ffcd4b994846c053.jpg?hash=p9KW8T1G5Q)
![[Hearth.com] Moisture meter and metal vac recommendations. [Hearth.com] Moisture meter and metal vac recommendations.](https://www.hearth.com/talk/data/attachments/128/128480-28180eac0b6f1ffa87633a119d62b754.jpg?hash=KvOoY4yPVS)
