so i bought a moisture meter from harbour frieght. when i split a split in haft and check it's moisture it reads about 15%. yet i put the wood in the stove and it sizzles. beside buy a new one any way to check calibration
A couple of ways. Maybe you can find a sample of known MC from a friend or something. Or find someone who has a different one to check against. A rather primitive but surprisingly consistent thing you can do is place the pins on your palm. Normally, it will read around 35%. It will vary some, but it's a quick and dirty check.beside buy a new one any way to check calibration
To get a good and true reading though ya got to push them in the whole way!^^^ this. I was going to say the same about the 35% palm reading, but be careful it can hurt a little if you press too hard trust me lol
I'm pretty sure that blood will read higher...but be careful it can hurt a little if you press too hard trust me lol
Pine and other high resinous wood can appear to sizzle even when well seasoned. I see that all the time, but in my case at least, it's just the pitch melting and sizzling and then burning. Sometimes, an otherwise well-seasoned split can sizzle a bit of water near the bark, usually just a little from rain, or from being buried in the stack near the bottom.Having said that I've had well seasoned pine that I burn outside in the fire pit sizzle some.
That's why ya gotta push it all the way into the bone.I'm pretty sure that blood will read higher...
Let us know how that works out for ya....That's why ya gotta push it all the way into the bone.
Dem Bones, dem bones,dem DRY bones.
See?
I'm cracking up! Good stuff CenterTreeThat's why ya gotta push it all the way into the bone.
See?
Now that I have a working three-year system, I don't often use the MM anymore, but there are plenty of cases where I don't know for sure. And there are times that I'm just curious. My MM cost a whopping $12 and is right there handy. IMO, there is little reason not to have one.For me having a moisture meter is a great tool. Since I burn softwoods that are often standing dead and go into the stove 6 months later I like to know where in my yard to put different wood for the final stage of drying. I dont go to crazy with this but poke a number of fresh splits before they go in the stacks. The three year plan works great for those who have the space but many of us dont. One point that hasnt been mentioned above unless I missed it is that if the wood is cold you will get a low reading. They are calibrated to doug fir in most cases and give optimal readings when the wood is around 70f. I also find it interesting when Im splitting and testing to probe it in the center as instructed but I also like to play around a bit and stab it closer to the outside. Sometimes Ill see wood that is 17% in the center and then find its quite a bit higher on the outside. Enjoy!
I read a post on the Hearth about using a multi meter to check moisture in wood. I believe it's on here somewhere, use the search and hopefully you find it..so i bought a moisture meter from harbour frieght. when i split a split in haft and check it's moisture it reads about 15%. yet i put the wood in the stove and it sizzles. beside buy a new one any way to check calibration
