Howdy - Been reading your older thread here about the Homewood furnace.  We are just trying to get going with one that was in the basement of the house we recently bought in Maine.  Didn't know what kind of thermostat this was till I read Bill 54s post.  Ours must have quit, as last owner rigged squirrel cage fan to a switch on the wall.  Does it make sense to try to fix the old setup?  I was going to put a spring wound timer in place of the switch, but if furnace could turn on fan according to temp I think that would be better.
Ours is ducted into the whole house system and we're preferring it to the wood stove in the living room as that will overheat just that one space, plus it takes smaller wood, so more cutting & splitting.
The expansion spring intake still works well. Our only problem is we want to shut the furnace down more, as packed chock full it only goes for 3 hrs max. I can see it needs a new seal on the door, which I've done before, but can't believe that will slow it down much. We're burning a mix of fir & locust, occasional pieces of birch, apple etc. Any suggestions? Does running the fan accelerate the burn rate? This may be related to something I see in the back of the firebox which looks like baffles or another chamber that has lost its integrity & looks partly broken away. I'll try to get a pic of this next time its cool. We're going thru a lot of wood and it's not even winter yet!
