I was at the farm for the last two weeks getting all the dirt work done around the outside of the barn. The back door was almost unusable. As it was built into the side of the hill and the hill side was too close to the door. It also needed the temporary ditches moved back and permint one put in. I had to clear all the woods off first since I already have too much firewood I was just giving it away. Then make a place to put all the dirt I had to remove. I used the dirt I removed to make a 20' tall pyramid that is going to be the base of my observation tower that I am also going to put my wind generators on.
Here's the back of the barn as I left it last year
(broken image removed)
The ground was a hardpan with rocks and boulders and my little dozer would barley cut it but the excavator didn't have much problem.
I also had to clear the woods for a area to dump the dirt. And make a road to get the truck back there.
Since I am going to use the dirt for the base of my tower and I want it compacted not loose. I put it in in lifts. Which means I dumped it spread it out 1' thick and ran the dump truck over it to pack it down.
Got the south and west sides done. All the ground slopes away from the barn leaving it two feet higher than the ground around it so all the water runs away from the barn and stays out of the subgrade keeping dry in and under the barn. I dug it back 60' from the back door to leave me plenty of room to pull trailers through and park equ.
The back of the barn done other than hualing in and spreading gravel for the parking area.
My dirt hill after I got it shaped up.
View from the top of the dirt pile. I always wanted a fire tower. I got some 20' pallet racks from a friend a few years ago and I am going to put one up on top of the hill getting it above the trees giving me a really great view!
It was a lot of work and I burned over two hundred gallons of diesel fuel doing it. But it sure feels good to have it done!. Moving the dirt wasn't the hard part. The hard part was clearing all the trees and stumps off of it.
This is the fourth or fifth load of firewood I got off it and I gave to my Uncle. I also have eight cords more I have piled up for myself. That need to be blocked up and split.
A good sized pile of cedar spruce and pine for the sawmill.
And a decent little pile of brush for a campfire to relax around!
Billy
Billy
