Hi Guys –
My first post here and my first foray into the world of burning wood. I have an opportunity to get my hands on a Morso 1125 wood burner as a “free to good home”. Unfortunately, it’s been stored outside, exposed and is in need of a little bit of work.
From my initial review of the unit, the firebricks are missing and the front door handle is rusted in position. I can’t open the doors. I’m hoping a liberal application of kroil and maybe some heat and I’ll be able to bust them loose. Other than that, there doesn’t appear to be any other damage.
Right now, my plan it to put in my shop, but would like to put in the basement of my house. So now the questions..
1. What is the round plate on the back of the stove for? It appears to be the same diameter as the top hole where the damper is. Is that for an alternate location for the piping?
2. Can I use standard fire bricks to line the stove? Given the age of this thing, I’m willing to bet that original fire bricks for this thing are rarer than hen’s teeth. I'm assuming there was firebrick on the bottom, left and right hand sides and back of the stove. Was there firebrick on the angled face as well? What about on either sides of the door?
3. The handle to open the doors is seized up. Which way does the handle rotate to an open position? I may need to tap with a hammer to get things moving and I want to make sure I’m turning the correct way. Right now the handle is in a vertical position and the doors are completely closed.
4. The damper freely moves, but the screws and clips that hold the damper to the top of the stove are rusted and seized, but I think easily fixed
5. Given the general condition of the stove, is it worth refurbishing or a lost cause? From the research I’ve done, it looks like a pretty good stove for heat, if efficiency is not a big concern. It will fit nicely in my 30x40 shop, but would be even nicer in my basement if I can vent the stove thru the wall to the outside, otherwise I’m stuck.
Any assistance or comments are greatly appreciated.
Joe
![[Hearth.com] Morso 1125 wood burner [Hearth.com] Morso 1125 wood burner](https://www.hearth.com/talk/data/attachments/182/182298-0a93e8028567836047f54ca39fba14b3.jpg?hash=KMmkiDcgYT)
Joe
