I just picked up a Morso 2B Classic off Craigslist. I'd like to install it in my entryway, and am trying to find the manufacturer's recommended clearances to combustibles. I have two questions I'd appreciate some help with.
1) I found a 2B Classic manual, which gives me clearances, but there have been many versions of the 2B Classic over the years and I don't know if my model matches the manual. You can see in the photo that mine doesn't have a glass door or an ash pan door, so I think it's an older one. Advice?
www.manualslib.com
2) If it's the right manual, the clearances it lists seem pretty tight. Which is good, since I have a small space. But I want to make sure I'm reading this right. It lists to unit as 27", and back wall to unit as 7". Many online references say you can reduce clearances by a factor of three if you install a sheet metal heat shield, which would make the side clearance 9", and the back wall clearance 2.5". Is that right?
Thanks in advance!
Positioning The Stove - Morso 2B Classic Installation And Operating Instructions Manual [Page 6]
Morso 2B Classic Manual Online: Positioning The Stove. Distance to walls and lintel When the stove is positioned near combustible materials, observe all current local and national building regulations with regards to clearances. Whatever regulations apply to your area, do not in any...
Thanks in advance!
