I'm hoping to gain some insight on "what to expect" in a future move we are doing. I'm burning with a Woodstock Fireview for reference.
We currently live in a poorly insulated 1,450 sq ft cape cod style home in central MA.
It is fairly closed off with a central staircase and rooms all around, the chimney is on the gable end with the brick outside running up the side of the house.
The house was built in 1948, has almost no insulation in the walls, the attic, or the floor of the first floor (basement ceiling). The windows are old and drafty, to the point where when I'm sitting on the couch in front of the window, I can literally feel cold air coming down the back cushions of the couch. (Sounds toasty right?)
We are moving to an 1800 sq ft home on the north side of a small mountain in central NH. It is log construction, built in 1985 with original windows. The roof has R30 insulation, the upstairs walls have R19, as do the gable end walls above the logs. The main walls are 8" D-log style logs, eastern white pine, supposedly good for around R13 or so. Being that it's settled now, there are certainly some air leaks that make it less than 'super insulated'. Being a log home, I don't know how much more I can insulate the walls.
The new home has a central fireplace/chimney with an open floor plan and cathedral ceilings.
I'm wondering what to expect if I move my Fireview up there, as far as if it will heat it better/worse than our current home. If it's not going to heat the house, I don't want to waste the energy moving it, and I'll likely go with a Woodstock Progress Hybrid or something similar as it's replacement.
I may use the Fireview in the basement (uninslated walls/slab) but being that it's in the
basement, I dont' want to go down there and load it every 5 hours or so. Something like a Blazeking would be a good fit for that.
Should I expect the newer home to be easier to heat with less wood, being that it's at least somewhat insulated? Or should I expect to need more heat and a larger stove since it's bigger and more open?
We like the house to be REALLY warm in the winter, let's say about 80 degrees or so.
I also want to start a new thread on the feasibility of installing radiant heat and heating with an indoor wood furnace, as well as the possible insulation options I may have, but I think that's for a different subforum, so I figured I'd start here.
